Hi,can anyone help me with a circuit diagram for this Philips tv .The chassis No. is LC4.7A so that i can do a repair on the main PSU.Have checked some caps that look ok but are ESR open circuit.Thanks Ray
Philips 42pf9946/79 plasma tv
Re: Philips 42pf9946/79 plasma tv
Can you post some pictures of the powersupply ?
If im correct the main problem on this set is the capacitors on the PS. They dont look bulged but the 10uf / 22uf need to be replaced for 100uf if im correct. It was a design fault.
Pictures please so we can help!I only repair Panasonic plasma tv's! Currently owning a TX-P55VT50 and still searching for a ZT60!
by celiabrownHello guys,
My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
Can someone has any symptom like this ?
Thanks​05-09-2024, 10:56 PM -
by alro7779Hello, guys!
The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601... -
by G33RTPhilips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
It does power up when pressing the power button.
I already try the power button while plugin the plug with no result.
Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
Could this be an PSU or eMMC issue ? -
by double_DDHi all,
Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
Not sure if this is something Philips proprietary, or a standard, but the cable plug... -
by janos6662000Hi
I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
When i applied cable signal to check image, i had normal picture, but TV was restarting.
I downloaded original firmware and applied the update, but the problem remained.
From a colleague i received a "factory package software" which is a lot bigger.
I made another firmware update, but still did not solve the problem.
Somewhere on the way the error got worse, because at the moment the... - Loading...
