Philips 42pf9946/79 plasma tv
  • ray1944
    • newzealand
    Hi,can anyone help me with a circuit diagram for this Philips tv .The chassis No. is LC4.7A so that i can do a repair on the main PSU.Have checked some caps that look ok but are ESR open circuit.Thanks Ray
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Philips 42pf9946/79 plasma tv
    Can you post some pictures of the powersupply ?
    If im correct the main problem on this set is the capacitors on the PS. They dont look bulged but the 10uf / 22uf need to be replaced for 100uf if im correct. It was a design fault.
    Pictures please so we can help!
    • celiabrown
      Issue with Plasma Philips 37inch chassis FTL2.1
      by celiabrown
      Hello guys,
      My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
      Can someone has any symptom like this ?
      Thanks​
      05-09-2024, 10:56 PM
    • Sharpa
      Repair attempt Philips 55OLED804/12
      by Sharpa
      I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
      The symptoms when bought: Philips logo appears then tv turns off
      Things tried so far:
      1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
      2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
      11-22-2025, 08:30 AM
    • alro7779
      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
      by alro7779
      Hello, guys!
      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
      09-14-2025, 12:25 AM
    • G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
      by G33RT
      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
      It does power up when pressing the power button.
      I already try the power button while plugin the plug with no result.
      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
      Could this be an PSU or eMMC issue ?
      07-19-2025, 03:43 AM
    • double_DD
      Philips curling iron - is this a common AC cable?
      by double_DD
      Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
      As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
      Not sure if this is something Philips proprietary, or a standard, but the cable plug...
      08-18-2025, 10:04 AM
