sony kdl-40w5500 no backlight or pic!
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    hey guys, this one is beating me at the moment and a little help would be awesome.
    lets start with some voltages. these are when powered on.
    cn6150 ps to main supply
    pin 1, power on, 3.358v
    pin 2, ac off detect, 3.402v
    pin 3, on/off, 3.397v
    pin 4, unreg 15v, 15.16v
    pin 5, unreg 15v, 15.16v
    pin 6+7, unreg 15v ground
    pin 8+9+10, reg 12v ground
    pin 11, reg 12v, 11.95v
    pin 12, reg 12v, 11.95v
    pin 13, reg 12v, 11.95v
    cn6151 ps to t-con
    pin 1, reg 12v, 11.95v
    pin 2, reg 12v, 11.95v
    pin 3+4 reg 12v ground
    cn6701 ps to inverter
    pin 1, vcc 12v, 11.92v
    pin 2, fb, 0.0v
    pin 3, fb, 0.0v
    pin 4+5 ground
    pin 6, ld, 11.32v
    pin 7, ld, 11.32v
    cn6154 ps to main
    pin 1, balencer err, 18mv
    pin 2, ground
    pin 3, inv err, 1.959v
    pin 4, backlight on, 1.6mv
    pin 5, dimmer, 2.3v
    pfc voltage is good
    after it trips the fault, it flashes 13 times once and then 14 times continually.
    14 blink is meant to be t-con error, but the initial 13 indicates balancer error.
    i have jumped the backlights on and they all seem good.
    i have got to the point where i know that i am not getting inv on and that inv err is high from the time power is applied, so i am looking towards the main board.
    just wondering if anyone else has any input on this one,
    thanks.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: sony kdl-40w5500 no backlight or pic!
    You have test points alongside the diode D101,102,103 etc. on the inverter board that you could test and see which point may be giving you the inverter error when you switch on. If your meter has min / max function it would help.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      there is no activity on any of those test points. there is no backlight flash with all hooked up, as i get the feeling that the main won't let it come on, that is why the error is high and bl/on does not go high. just how i see it anyway.
      btw, if i disconnect the error pin, it still reads high, so it has to be processed by the main i guess.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The Sony manual posted has the schematic of the power supply IP1 in it.
        It looks like IC6702 (page 46) is a comparator with one input (pin 11) connected to a resistor divider across VCC_12V and ground and the second input (pin 10) is from IC6700 (LX1692FIDW-TR) pins 18 & 19. The output of the comparator (pin 13) is the inv_err output.
        The comparator looks as though it monitors the drive output Aout and Bout of IC6700
        I suspect the fault is in the inverter circuit on the power supply board.
          "i have jumped the backlights on and they all seem good." If you are able to force on the backlights, then do you see image on the screen? You should if all other functions of the main board are OK, if not then you have more than just bad BL-ON problem on the main board.
          • attainteddragon
            • Apr 2013
            • 764
            • australia
            i put the ps on the bench and forced it on. the voltage on the cathode of the dual diode that comes from the comparator circuit reads around 100mv on both of those diodes. the 1.9v on the inverter error pin is NOT present. hooked it back up to the main and the same voltage is still on the diodes, but the 1.9v inverter error pin is now present again.
            bud, the main was fully isolated from the ps when forcing the ps on, so no picture on screen.
              I would hook everything back up, then remove the BL-ON wire going back to the main board and then use 1K between the BL-ON pin of the power supply and the STBY Voltage to force on the backlights to see if you will get the image on the screen when you turn on the TV, if not you have more than just bad BL-ON signal.
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                tried jumping the backlights with the main hooked up and it didn't give me pic. also tried grounding the error voltage to see if that helps, and still no go. error voltage is high from the time power is applied.
                i know that i have main issues due to no bl/on signal. so i will see if i can find one. i may of stripped one of these in the past, but need to sort and catalogue my stock. could take a while. :O
                  If you get the light source to come on, if the main board and T-CON boards are good then you should have pictures and sound, at this point it looks like you have main board problem, you can also check to see if you get 12V at SMD fuse on the T-CON, if the main board is good then it should also send the 12V to run the T-CON.
                  • attainteddragon
                    • Apr 2013
                    • 764
                    • australia
                    12v is present at t-con. fuse is good. not sure if this error voltage does anything else while on the main. found that it generates from the 12v on cn6150. with those pins disconnected, i don't get the error voltage, but lose functionality of the set at the same time.
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • dkneyle
                      Sony KDL-46HX850 Can't upgrade/update firmware
                      by dkneyle
                      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                      09-25-2024, 10:44 PM
                      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-06-2024, 05:27 AM
                    • rabbituk
                      Sony HCD BX7700dbi CMT flashing standby
                      by rabbituk
                      I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                      So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                      02-11-2025, 05:05 PM
                      Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                      This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                      09-06-2024, 05:30 AM
