LG 50PK550 no pic but has sound
  • jason424
    • Dec 2015
    • 187
    This set would have pic for a while then the pic goes out and just sound. Eventually the set would turn itself off. Sometimes the pic would come back for a while, sometimes just the sound. And now nothing.
    With the TV on, I tested VA and VS and they seem OK at 59 and 203 but I get really low numbers on the VSC and VY on the YSUS....3 and 2.8 respectively. The cable is delivering 59/203 to the YSUS.
    I also checked the connector from the power board to the ZSUS and all the pins going out show:
    NC: 5
    NC: 5
    NC: 0
    NC: 0
    NC: 0
    GND: 0
    GND: 0
    NC: 0
    VS: 203
    VS: 203
    I do have green blinking LED (1 long, 1 short) on the inverter board below the power board.
    Any help on what else to test to narrow down if it's YSUS, ZSUS, power or combo?
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50PK550 no pic but has sound
    Run test patterns on the control board with the lvds disconnected.
    Good patterns = bad main av board.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • slimmy182
      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
      by slimmy182
      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
      Looking on google I found this:...
      01-14-2023, 11:55 AM
    • mrtek
      Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
      by mrtek
      Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
      11-26-2024, 09:58 AM
