Good day folks, I got this here TV which randomly power-cycles. It turns on alright, but it turns off after a random interval, then comes back on...the relay clicks an uneven number of times during this cycle. After it's come on, it may work for 5 minutes or it may just cycle again. I think the green LED that's supposed to come on when it's working normally is dead, because I can't see it turning green - it only goes red when it's off and that's it, so I don't know if it flashes any error code using the green LED.
Honestly, I don't even know where to begin with this one and the lack of an ESR meter further accentuates the issue. To be fair, I think it's the main board that's causing this, but I started with the power supply anyway. Couldn't find a good schematic, but I struggled to follow the one I uploaded. I replaced the 3 2200uF caps on the 5v bus (C752, C756 and C768 on page 14 after the diode after the transformer) just for good measure and also two little 47uF ones (C723 and C735 on page 13) since they've sat near those heatsinks this whole time, but the problem's the same: can't isolate the fault no matter what. I get 5v, 13.6v and 35v alright....stumped.
I've also added a photo of the main board, though I don't think that's the actual "main board" which has the brains on it, since all I see are the scart and RCA connectors on it. There's another board right above it and I think THAT is the actual CPU and whatnot, but it's just a metal plate so no real point in taking a picture of that. The only reason I'm showing it is because I see some caps there too....probably something for the audio amp, but who knows...maybe someone knows something I don't :| Has anyone repaired this model ? Not too much information out there either...Cheers
) a few pads which seemed slightly dry, but the problem's the same sadly
