Sharp Aquos lc-37ra1e random power cycles
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks, I got this here TV which randomly power-cycles. It turns on alright, but it turns off after a random interval, then comes back on...the relay clicks an uneven number of times during this cycle. After it's come on, it may work for 5 minutes or it may just cycle again. I think the green LED that's supposed to come on when it's working normally is dead, because I can't see it turning green - it only goes red when it's off and that's it, so I don't know if it flashes any error code using the green LED.
    Honestly, I don't even know where to begin with this one and the lack of an ESR meter further accentuates the issue. To be fair, I think it's the main board that's causing this, but I started with the power supply anyway. Couldn't find a good schematic, but I struggled to follow the one I uploaded. I replaced the 3 2200uF caps on the 5v bus (C752, C756 and C768 on page 14 after the diode after the transformer) just for good measure and also two little 47uF ones (C723 and C735 on page 13) since they've sat near those heatsinks this whole time, but the problem's the same: can't isolate the fault no matter what. I get 5v, 13.6v and 35v alright....stumped.
    I've also added a photo of the main board, though I don't think that's the actual "main board" which has the brains on it, since all I see are the scart and RCA connectors on it. There's another board right above it and I think THAT is the actual CPU and whatnot, but it's just a metal plate so no real point in taking a picture of that. The only reason I'm showing it is because I see some caps there too....probably something for the audio amp, but who knows...maybe someone knows something I don't :| Has anyone repaired this model ? Not too much information out there either...Cheers
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Sharp Aquos lc-37ra1e random power cycles
    By some freak accident I managed to find an uncut schematic here.
    Wattevah...
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Are there any poor solder joints on the power supply or mainboard? Are the two fans freely spinning?
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Oh yeah, I forgot to mention: the schematics show some fan connectors as well, but mine doesn't have them or the fans - the PSU just fits different models. Solder joints: I've already reflown (hope it's spelled right ) a few pads which seemed slightly dry, but the problem's the same sadly What I'm thinking of doing next is pulling out the PSU again, turn it on on the bench and loading it with some lamps and let it "suffer" like that for as long as possible to see if it crashes. I HIGHLY doubt it will, which would confirm that the main board is faulty and it's randomly removing the "PSU_ON" signal...
        Wattevah...
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          I made another discovery: the 30v line is running too low (even under no load). It only reads around 23v which I don't think is appropriate. It comes out at PL703 on the right side of the schematic. Haven't yet replaced the caps on that bus...perhaps it's a simple issue after all.
          Wattevah...
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Could be indeed some bad caps , maybe backlight asking to much from the PS?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Test was done with PSU on the bench and nothing connected, so there was no power draw. The 13.5v bus is also a bit low: only 12v and drops to 11 something when I load it with a lightbulb. Replaced caps.
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Another thing I noticed, which didn't make sense at first is those little numbers next to some of the pins of some components. Apparently they indicate what value that pin should read, as many of them match my reading, except for the one at shunt regulator IC705: pin 3 of that should read 4.4v, but mine reads around 8v (almost double)...the resistors around it read fine...could it be a bad optocoupler ? Funny thing is that the values at the optocoupler also match the ones in the schematic....
                Wattevah...
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  IC705 (MR4020) pin3 is labelled GND = 0V?
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    I think I managed to fixed it, more through freak luck than anything else: I replaced those two small caps at the upper-left hand side of the PFC coil (right above where it says "PRI" on the circuit bord) and the TV hasn't power-cycled anymore up until now. Will have to let it run for a full day before I can return it, but I think that was the issue - it gets VERY hot in there, but funnily enough, if this is indeed what was causing the reboots, those caps are out in the open and not next to any hot surfaces, so it's interesting they failed but none of the others did. Can't remember exactly what those caps are for...they followed on the primary side somewhere after the optocouplers (the transistor side of the optocoupler) and also did something with those TXA chips which nobody's heard about and there's no datasheet for them, so I don't know what they are. So anyway, if someone's having the same issue, consider replacing those two caps. Cheers.
                    Wattevah...
                    • scubacamper
                      Sharp Aquos LC-70C6400U Half Screen Dark
                      by scubacamper
                      I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                      Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                      when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                      05-03-2025, 12:19 PM
                    • sefoster
                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                      by sefoster
                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                      11-20-2022, 09:29 AM
                    • jonah1024
                      Sharp Aquos LC-40UG7252E LCD TV burn in?
                      by jonah1024
                      Hello!
                      I'm a few days old into this TV screens repair universe so please bear with me.
                      Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                      - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                      - I did a factory reset as well...
                      07-16-2024, 04:23 AM
                    • klassic
                      Sharp Aquos LC-60LE635E three blinks
                      by klassic
                      Hi community,
                      I will describe my problem with a TV in those short following terms to be the most precise :
                      What i have :
                      power board DPS-162KP-1
                      main logic board QPWBXF733WJN2
                      symptoms :
                      white led light logo at startup,
                      after 2 minutes, blinking 3 times a row, repeating
                      no backlight (and apparently no picture, checked panel with flashlight)
                      no startup sound
                      powerboard investigations :
                      1-2 PNL : 0v
                      3-4 GND
                      5-6-7-8 UR : 13.15v
                      9-10-11-12...
                      10-24-2023, 01:39 PM
                    • foxyUK
                      Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                      by foxyUK
                      Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                      The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                      There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                      10-22-2024, 10:27 AM
