Vizio E470i-AO - Backlight LED Problem
  • grimacelord
    • Jan 2017
    • 383
    Re: Vizio E470i-AO - Backlight LED Problem
    Originally posted by budm
    I have a feeling one or more LED strip has open circuit...
    Thanks for getting me this far, budm! What should I do next now that we've come to this point?
      So one or more of those three strip (each strip has two sub LED strip) may have open circuit at the connectors or open LED, so it is a matter of finding out which one.
      • grimacelord
        • Jan 2017
        • 383
        Alright. So I'm still checking for continuity and basically go through those strips and sub strips at each connector and LEDs themselves until I find an open circuit?
          What you can do is to remove one of the three working strip (one strip contains two sub strips) and replaced it with one of three dead strip at a time to find out which one of the 3 strip is bad. One caution, those SMD connectors are very fragile so the solder connection gets broken easily and you have already removed and installed the strips many time so be real gentle with them, I usually re-solder them all for precaution.
          This where LED tester come in handy.
          • grimacelord
            • Jan 2017
            • 383
            Ok, awesome! Using this method, I have identified two sub-strips that cause the set of 3 to not light. All of the other sub-strips work fine. It's only these two sub-strips. Each are an end that would connect into the green bar first and then another sub-strip would connect into these strips to finish the strip out.
            I suppose, and correct me if I am wrong, one or more of these LEDs on these sub-strips has an open circuit and is preventing the rest of the set from working, right? I just have to identify which one. I have replacement LEDs handy. I could just replace ALL of them, since I don't have an LED tester unless you have any other suggestions?
            Wow, thanks for the help so far! This thing might actually get fixed today!
            • grimacelord
              • Jan 2017
              • 383
              Pic of bad sub-strips for reference:
                That is correct, you should find out which LED has open circuit, which one may have shorted circuit. Replacing them all may be the best choice.
                BTW, look at the bottom side of the strip to see if any of them has brown spot due to over heat.
                • SLK001
                  • May 2014
                  • 264
                  These TVs usually fail due to the LEDs opening. Since they are in series, if one goes, they all go for that circuit. Make yourself a simple LED tester by either taping two 1.5V batteries together, or use a power supply, and run the wires to two straight pins. On the good strip, probe the two pins to the LED until it lights up. Once you have gained confidence in your technique, proceed to the bad strip and test every LED. There may be more than one bad, so don't stop at the first bad LED. Once you have found all the bad LEDs, pop off the lens and simply replace them, then TEST your work in circuit and if it works, epoxy the lenses back.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    #29
                    Should you replace individual led's make sure lens is centered over led or you will get bright spots on screen
                      I would suggesting using current limiter power supply or if you batteries is to limit the current because if the applied Voltage is backward, the protection diode (which is connected in anti-parallel with the LED, not all LED has protection diode) will be fully conduct due to 3 Volt being applied to 0.6V diode junction so you can short out the protection diode. Always limit the current for protection in case of wrong connection.
                      • grimacelord
                        • Jan 2017
                        • 383
                        So, I wanted to post back an update. I was able to desolder the LEDs from the LED strips I mistakenly bought and solder them onto the original LEDs strips for just ONE of the strips. The others didn't seem to want to work. In the interest of time, I purchased the remaining strips I needed and just received them. I connected them all back together, and now all of the strips are fully illuminated!
                        So now I will begin reassembly and I will show the final working product (hopefully!)
                        Thanks for all the help and hopefully reassembly is without problems. Attached a picture of fully illuminated LED strips for reference.
                        • grimacelord
                          • Jan 2017
                          • 383
                          Awesome! Works! Thanks a ton, budm! I've learned quite a bit more about how these TV's operate from reading your posts and throughout this exercise! I'm sure I'll ask for help again in the future.
                          Attached pic of working TV for reference.
                            Thanks for the follow-up on the repair.
                            • howardc64
                              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                              by howardc64
                              Failure Symptom
                              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                              Where is the short?
                              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                              05-27-2025, 02:56 PM
                            • Yanleb
                              Vizio M70-D3 4K with dark spots backlight issue
                              by Yanleb
                              I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                              On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                              I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                              03-22-2022, 01:06 AM
                            • smort
                              Backlight Polkadarks
                              by smort
                              Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
                              I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
                              03-11-2025, 12:33 AM
                            • JaquesPratt
                              Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                              by JaquesPratt
                              I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                              This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                              07-16-2024, 01:04 AM
