Sagemcom RT195-320
  • Tips
    • Feb 2014
    • 15
    Sagemcom RT195-320
    I have a Sagemcom RT195-320 in which the hard drive has died and is totally unrecoverable. Not even detected when put in to a PC or connected as an external drive to a laptop.
    I have hence installed a new sata hard drive but can not get the software required to load. I have down loaded the software from the Sagemcom website but it fails to install as this seems to be an upgrade package not the full version of the software.
    Does anybody have the software for one of these devices, or one of these devices that am image can be taken from a working a drive to try and get the unit working.
    Any assistance, guidance and help will be most appreciated.
    Thanks in advance
  • R_J
    • Jun 2012
    • 9624
    Re: Sagemcom RT195-320
    I found some information here https://forums.digitalspy.com/discus...d-disc-problem not sure if it will help
    • tmcw
      PC case - Hard drive rails
      by tmcw
      A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
      So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
      I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
      Now, the case is a CiT Gaming Case, and...
      05-22-2022, 12:04 PM
    • ash91
      Hp pavilion 15 not detect hard drive
      by ash91
      Hello gentelmen .... this is my first post and sorry for my bad english,
      so my proplem is my laptop keep losing hard drive even if i but the
      hard disk in the cady (the box that can replace the dvd rom with hard disk)
      when i turn the laptop on the massage that said no boot media found pop on
      the hard disk is fine and to be sure i try another hard
      i also update my bios to the last update
      the 5 volt is present on the hard connector on the motherboard
      the dvd rom work fine when i but a windows dvd in it
      also when i boot from flash...
      06-07-2023, 01:45 PM
    • federalhouse
      **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
      by federalhouse
      I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
      **Background:**
      I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
      **What I've Tried So Far:**
      1. I accessed
      08-01-2024, 07:03 PM
    • karto95
      Repairing a Seagate hard drive with damaged logic board
      by karto95
      I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
      I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
      If anyone has any suggestions or experience with this...
      03-21-2023, 04:05 AM
    • ChaosLegionnaire
      bug of the month: write caching setting for the hard drive in device manager
      by ChaosLegionnaire
      i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
      so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
      10-06-2019, 01:39 PM
