Sony KDL-46XBR2 only PC input??
  • kgavionics
    • Apr 2017
    • 152
    hi
    i have a non working Sony KDL-46XBR2 when i turn it on the green light is on, but no backlight or picture.i checked everything and i trace the problem down to the main board.Luckly, i had the exact mainboard in my storage room.replaced the mainboard and when i turn it on nothing happens ( the same symptoms) , but if i press on the source button on the tv i can scroll between only two inputs.either the regular tv ( snowy picture or Video 9).if i hoock up the tv to my computer i get a very good picture.
    i want to know if someone has an idea what's going on?why i don't have the other inputs ( HDMI1,HDMI2, components...)
    thanks in advance
  • petehall347
    • Jan 2015
    • 4450
    Re: Sony KDL-46XBR2 only PC input??
    is the replacement board guaranteed working ? did it come from same set using same everything else ?
    did you try things like factory reset ?
    • R_J
      • Jun 2012
      • 9624
      Are the other inputs greyed out in the menu or not listed, Try a factory reset (see manual)
      • kgavionics
        • Apr 2017
        • 152
        the replacement board is from another exact model.
        My problem i can't do a factory reset with the remote.I can use the remote for certain things for instance if i press on volume, channels menu...it works, but other button like power , tv/video are not working.
        is there any other way to do a factory reset without the remote control?
        • R_J
          • Jun 2012
          • 9624
          I don't know, but I don't think so. here is a link to a service manual but may not help I did'nt see any firmware updates for this model either
          • csmith
            • Aug 2014
            • 46
            Have the same set which had the same issue problem was open fuse
            on the tcon board.
            • csmith
              • Aug 2014
              • 46
              Never mind realized your set has a picture over the rgb!
              • kgavionics
                • Apr 2017
                • 152
                I fixed the problem, it was a fuse on the QM board.The QM board is the board that generates the user menu.Tv is working good now.
                Thanks for your inputs guys
                • Tarot Superstars
                  Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
                  by Tarot Superstars
                  Hi.
                  I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
                  Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
                  Where in the circuit is the best place to solder the 3 stereo input wires?
                  This is the model and schematics:
                  https://www.manualslib.com/manual/91...7l.html#manual
                  10-31-2023, 03:23 AM
                • ugamazing
                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                  by ugamazing
                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                  04-10-2024, 08:06 AM
                • Carlos#2003%
                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                  by Carlos#2003%
                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                  02-15-2024, 07:52 PM
                • alfatv
                  Sony STR-DH520 no optical input
                  by alfatv
                  Hi guys,
                  This is my own (actually present to gf) amp which I am not even using so much.
                  Recently started to use optical input from TV which worked great.
                  However recently the link went down.
                  Few days ago I opened it up, cleaned PCBs from dust, then came back to life.
                  But today it did the same thing again.
                  On TV when I change setting from speakers to just optical and other way around, audio comes up only for very short moment.
                  There are 2 optical inputs, both behave same way.
                  I found schematic which is attached.
                  I hope this forum experts...
                  02-24-2023, 09:39 PM
                • dkneyle
                  Sony KDL-46HX850 Can't upgrade/update firmware
                  by dkneyle
                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                  09-25-2024, 10:44 PM
