Sony STR-DH520 no optical input
  • alfatv
    • Sep 2020
    • 353
    Hi guys,
    This is my own (actually present to gf) amp which I am not even using so much.
    Recently started to use optical input from TV which worked great.
    However recently the link went down.
    Few days ago I opened it up, cleaned PCBs from dust, then came back to life.
    But today it did the same thing again.
    On TV when I change setting from speakers to just optical and other way around, audio comes up only for very short moment.
    There are 2 optical inputs, both behave same way.
    I found schematic which is attached.
    I hope this forum experts can point in right direction, thanks.
  • jons
    • Feb 2014
    • 59
    • Latvia
    Re: Sony STR-DH520 no optical input
    Either that digital input receiver IC is dying or there's some cold solders on that input board would be my first guess.
    • Devil_rider
      • Jan 2023
      • 33
      Any other optical source or Amp to test the TV also? The fact that it works when you change settings on TV would make me look at TV first.
      • alfatv
        • Sep 2020
        • 353
        Working again right now.
        It was the same problem with another TV and with another optical input of the amp.
        • Devil_rider
          • Jan 2023
          • 33
          All digital inputs are going to digital interface ic 2006. Check the power for noise/ ripple and you probably did that but reseat connectors on digital board to main board.
          • Tarot Superstars
            Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
            by Tarot Superstars
            Hi.
            I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
            Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
            Where in the circuit is the best place to solder the 3 stereo input wires?
            This is the model and schematics:
            https://www.manualslib.com/manual/91...7l.html#manual
            10-31-2023, 03:23 AM
          • ugamazing
            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
            by ugamazing
            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
            04-10-2024, 08:06 AM
          • ahmedtou
            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
            by ahmedtou
            help me please
            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
            I will share all the details with you, including the disc information.
            Code:
            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
            Current Profile: BD-R
            Disc Information:
            Status: Empty
            State of Last Session: Empty
            Erasable: No
            Free Sectors: 12,219,392
            Free Space: 25,025,314,816 bytes
            Free Time: 2715:27:17 (MM:SS:FF)
            Next
            08-27-2025, 08:49 AM
          • Carlos#2003%
            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
            by Carlos#2003%
            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
            02-15-2024, 07:52 PM
          • dkneyle
            Sony KDL-46HX850 Can't upgrade/update firmware
            by dkneyle
            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
            09-25-2024, 10:44 PM
