th-p50x20m for now flashing 6 tims ,was flash 10 times
  • kobkobk
    • Sep 2011
    • 28
    Dear friends. After a few days and quite a few hours of work and searching, I turn to the professionals for help
    I have a plasma that initially had a fault of 10 flashes, no 187
    +60 Volt was in power supply replaced the component has been repaired, for now, switched on The tv- green light flashes several times and then the red light flashes 6 times,
    From reading and reading it is clear to me that this is the CS card where the problem is, but many tests and quite a bit of time has been devoted to the search. CS does not seem to have a problem, all the tensions exist VAD, 16V-F 15,15V 5V all the FETs good,no shorts
    moved f.f I have turned off the SOS 6,7,8 result - a red light is no longer flashing, a green light is on but there is no sign of life on the screen
    From my tests I found that the component that controls all the [FET] IC9300 does not take out any pulse or life signal.
    This main component is located on the A command card
    After much effort, I managed to get a 42-inch command card, without any change. The card I received was not checked. it was dismantled from an unknown device and I do not know if it is usable
    Please if someone knows and can give direction,In some plasma screens the manufacturer can test the units of the screen by short circuit T, CON Can this be done also on this device?
    thanks
    kobi
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: th-p50x20m for now flashing 6 tims ,was flash 10 times
    Why did you post 3 times?
    • kobkobk
      • Sep 2011
      • 28
      Yes, there was a technical malfunction on the computer
      I believe it is not terrible and I will still get an answer
      kobi
      • tw2005
        • Oct 2011
        • 6458
        Have you checked the SS board, any shorted RJP30E4 igbt surface mounted x 4?
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • STKR123
          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
          by STKR123
          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
          I wonder if re-flashing the BIOS might be of any use here.
          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
          11-03-2024, 06:58 AM
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • reessi
          HP 14-CE0523SA (14-CE0000 Series) - DC / Charge LED Flashing 5 Times White!
          by reessi
          DA0G7AMB6D1 REV.D Board:
          A strange fault occured while I was calibrating the battery. This battery had not been used for a while.
          Previously to calibrating the DC/Charge LED operated normally:
          Off when no charger,
          Solid Orange while charging with Charger,
          Solid White when 100% Full with charger.
          I charged to 100% then left it playing a long youtube video,
          as expected the guage was wrong and it just cut off before reaching the low percent where it would sleep.
          It wouldn't power on so I plugged charger expecting to...
          07-06-2023, 09:59 AM
        • rivetcity
          Panasonic TX-P42UT30E, IGBTs on the SN board
          by rivetcity
          I'm having problems with my plasma Panasonic p42txu32e. The issue started about 12 months ago.
          I have a remote controlled main outlet so whenever I turn off the TV set at night, I also switch off the whole power outlet.
          It gives me a better feeling to know I don't have 230V on any cables, so my dog can't get hurt if he gets the idea to start chewing on something.
          About 12 months ago the TV started to have the following problem: when pressing anything on the RC to get it on, the red led would go off.
          Sometimes it would turn...
          08-12-2021, 01:25 AM
