th-p50x20m for now flashing 6 tims ,was flash 10 times
  • kobkobk
    • Sep 2011
    • 28
    Dear friends. After a few days and quite a few hours of work and searching, I turn to the professionals for help
    I have a plasma that initially had a fault of 10 flashes, no 187
    =60 Volt was in power supply replaced the component has been repaired, for now, switched on The tv- green light flashes several times and then the red light flashes 6 times,
    From reading and reading it is clear to me that this is the CS card where the problem is, but many tests and quite a bit of time has been devoted to the search. CS does not seem to have a problem, all the tensions exist VAD, 16V-F 15,15V 5V all the FETs good,no shorts
    moved f.f I have turned off the SOS 6,7,8 result - a red light is no longer flashing, a green light is on but there is no sign of life on the screen
    From my tests I found that the component that controls all the [FET] IC9300 does not take out any pulse or life signal.
    This main component is located on the A command card
    After much effort, I managed to get a 42-inch command card, without any change. The card I received was not checked. it was dismantled from an unknown device and I do not know if it is usable
    Please if someone knows and can give direction,In some plasma screens the manufacturer can test the units of the screen by short circuit T, CON Can this be done also on this device?
    thanks
    kobi
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • STKR123
    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
    by STKR123
    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
    I wonder if re-flashing the BIOS might be of any use here.
    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
    11-03-2024, 06:58 AM
  • abajor
    Canon VIXIA HF S10 A read data from inernal flash memory.
    by abajor
    Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
    Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
    The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
    I think my best shot is to figure out a way to read the internal flash memory outside...
    07-20-2024, 12:04 AM
  • Ihandyrepair
    4 red flash led 65X950G boot Sony and android logo but then black
    by Ihandyrepair
    HI guys
    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
    here is the issue
    I have Sony and android logo. but then 4 led red flash lights front of the tv
    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
    but then I get black screen and 4 red flash light at the front LED
    but I get 3 led flash on the LED driver board.
    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
    so I tried...
    07-11-2024, 01:45 AM
  • abhorsen
    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
    by abhorsen
    Hey guys,
    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
    07-06-2023, 10:22 AM
