Vizio E421VA flickering backlight when powered on
  • Lazarus65
    • Jul 2017
    • 5
    When I power on the TV it flickers rapidly for several seconds then the screen goes blank. The lights are still on but there is nothing on the screen. No menu or information. I have checked all the boards and the only thing that appears to be faulty is a thermistor. I have tested the power board and all the correct voltages are there. From the other threads on here it appears to be the main board voltage regulators. Nobody on those threads have confirmed that fixed the problem. How do I test these?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E421VA flickering backlight when powered on
    Some good pictures would be helpful
    • Lazarus65
      • Jul 2017
      • 5
      I have added a picture of the mainboard. The thermistor just had a bit of old gunky flux that was easily scraped off. Research from other posts suggests the mainboard to be faulty. ShopJimmy appears to be sold out of this model mainboard and the mainboard kits don't show my same model number.
      • Lazarus65
        • Jul 2017
        • 5
        Any ideas on where to find parts for this main board? Here is the model and board number: CBPFTXACB5K008 (TXACB5K00808)
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • mrtek
          Vizio M65-C1
          by mrtek
          Hi.
          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
          07-14-2025, 07:28 PM
        • xeos
          10 year old Vizio VO370M has intermittent flickering backlight
          by xeos
          I have this Vizio VO370M TV that I'd like to save because it has very low input lag (as good as the most expensive TVs sold today!, https://alantechreview.blogspot.com/...input-lag.html), but it has a very annoying issue: sometimes the backlight flickers (or is just kind of dim). The flicker is slower than 60hz, so we aren't just talking some kind of motion compensation).
          I was hoping maybe it was a power board issue (aka failing caps) but I opened it up and I don't see any that look bad. I have a budget capacitance/ESR meter if it's worth checking those...
          05-14-2021, 03:39 PM
        • DrvLikHell
          Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
          by DrvLikHell
          Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
          The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
          07-05-2024, 02:54 AM
        • EvazX
          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
          by EvazX
          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
          However, after some time, the replacement motherboard...
          08-25-2025, 06:09 PM
