Hi guys,i found this LCD OLEVIA 232-12 with Power blue light and backlight is on,i have the 5v ,12v,23v,voltages,no bulging caps,anybody has clue of what could be?
Olevia 232-S12 no pic
Re: Olevia 232-S12 no pic
http://www.shopjimmy.com/olevia-aep0...er-supply.htm#
http://www.shopjimmy.com/olevia-sc0-...or-232-s12.htm
http://www.shopjimmy.com/lg-philips-...-con-board.htm
http://www.shopjimmy.com/lg-philips-...rter-slave.htm
http://www.shopjimmy.com/lg-6632l-03...ter-master.htmLast edited by ivtec; 07-05-2017, 03:38 PM.Comment
do you have continuity across f1 on the t-con board? marked tk.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
attainteddragon;Thanks once again,i just went to measure on F1 TK both sides and have 12v,one thing i notice the back-light has kinda faded blue color normally you see the back blight faded gray dark?
Here the Service manual but the points of the pins for the 5v,12, differ from what is actually in this board,
https://www.manualslib.com/manual/77...a-232-S12.htmlLast edited by ivtec; 07-05-2017, 06:28 PM.Comment
not much of a manual. :/
i would disconnect one side of the t-con ribbon cables at a time to see if you get a pic at all, other than that, scoping the lvds to confirm signal to t-can would be handy.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Hi attainteddragon;thanks i disconnected 1 ribbon cable and turned on tv and i get Half screen gray half white,i did the other side something, also removed and wiggled one side of the LVDS wire and i had pink and blue,i don't have a scope,is there any component or board i should look over, thanksComment
Pin 2 is the output so it looks as though you have either a defective regulator or something is shorting the output. I would lift off the regulator and check it and if the regulator appears OK then check if pin 2 solder pad is still shortedLast edited by dick_barton; 07-07-2017, 01:04 PM.Willing to help but I'm no expert.Comment
The 1117 regulator comes in several different voltage outputs. Are you sure the replacement was the same output as the original? Suggest you remove regulator and check output pad to ground for a short. Actually, you should have done what dick suggested while you had the original regulator off the board.Last edited by jetadm123; 07-07-2017, 05:58 PM.Comment
That is inductor (Ferrite bead: FB????), it looks to be for feeding the Voltage to the regulator. You should have checked the resistance on pin 2 and pin 3 pads against GND before installing the new regulator first, then you check it again after installing new parts to make sure you did not have any solder bridges.
Right now you have shorts circuit that need to be found first.Last edited by budm; 07-07-2017, 07:25 PM.Never stop learning
Thanks guys,My fault i should not have installed that regulator that i found out was a 1777 but adjustable reg. besides the board is all bad from the start,not worth it, i was taken from trash,and to trash it goes ,not spending a red penny on this,maybe i'll keep it for awhile maybe i'll find another one like this for parts,thanks anyway.Comment
Hi guys ;i've got another main board from Ebay and it does same thing,today i went to test voltages per service manual that downloaded from the site but this service manual misses the schematic for Voltages,but the trouble shooting tree has some tips,.
i have fallowing needed voltages
CN904-pin 7 to Ground =5v,Pin 8=5v
also have main Board Cn 4 - pin 1 to GRD =5v,and Pin 3=5v
CN 5 -Pin2 to Grd = 12V
But i went to check the 12 volts at the T-con board and 12v missing,the fuse is OK,so not 12 v reaches T con fuse,
what does that tells you/ any other advice,i'd hate to a buy a t-con board and waist more money,thanksComment
if you do not have 12v at the input of the fuse, then it will be the main board. just to make sure, disconnect the t-con and check to see if the 12v comes up or not.
with this replacement main board, do you have your voltages on the regulator position that you replaced on the last board?WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
attainteddragon;I don't have no voltages from previous regulator position,also do you mean the 12v on the main board ? I have the 12v at Cn5 pin2,does the 12v from main board goes throughout the LVS cable to T-con ? Here a pic of the screen i have don't mind the reflections it's kinda faded bluish,someone told me this pic is symptoms of a bad T-con,i hate to spend more money on this,thanksif you do not have 12v at the input of the fuse, then it will be the main board. just to make sure, disconnect the t-con and check to see if the 12v comes up or not.
with this replacement main board, do you have your voltages on the regulator position that you replaced on the last board?Last edited by ivtec; 09-11-2017, 08:30 AM.Comment
by JhhhhI searched all websites but nothing.
this is bored id 6050A3316601-MB-A01-
Channel: Schematic Requests ONLY!
07-30-2025, 07:10 AM -
by Ancient1CROWN Smart TV, 50", Single board design
1. TV starts with Wall power..
2. The front LED is blinking very fast that it looks like a red&green LED
3. The Android Menu in the photo appears
4. Buttons are not responsive
I tried few pre_Power Button Combos, and with Power, but none worked
I'm scratching my head how to start diagnosing.. ??... -
by cadar21hi guys looking for a FW UPDATE FOR MY oLEVIA 47'..
the screen is freezing an the audio continues to play...
my current fw is
--FRW--747-B11_V63.7.5A17 VLCD78310263
if that helps...my research leads nowhere...i guess the website is no longer available since Olevia filed for banckrupcty....
any help would be appreciated.. looking for the USB fw..
Olevia - 747-B11
FM1-04700E-S0012-13-2017, 03:13 PM -
by Cory MeyersHi there all, 1st post here. I wasn't aware there were guys out there doing this for people! (how, well I haven't a clue lol but 😎👍 badass!), So when I found y'all, I was happy, but not too happy quite yet - although my issue seems to be less severe than many I've seen here who have been happily helped, so there's that.
I'm a software dev of over 20 years and just recently have gotten into the hardware side of things plus other electronics like Rpi and Arduino. Started off a vid game hacker yada yada, same story. Lol.
Now, the BIG OL' issue ruining me little life:...-
Channel: BIOS Requests ONLY!
by hispeckHello all, I need help on olevia tv service manual. The model Lt23hvx12-03-2018, 05:12 AM
- Loading...
