BN44-00496B A5V only have 2.2V
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: BN44-00496B A5V only have 2.2V
    Use your meter in diode mode and check between Source/Drain of the FDD7N25LZ. You should be able to measure the diode across the internal package. High one way, low reading when leads reversed.
    • jeremykum
      • Feb 2012
      • 95
      • Malaysia
      Black = drain
      red = source
      0.480v
      reverse it, 0v
      Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
      • jeremykum
        • Feb 2012
        • 95
        • Malaysia
        BTW I did some test.
        I remove 3 diodes in red circle, and I get 190VDC at LED socket D1/DI
        Checked these 3, all ok, diode test same reading.
        Soldered it back, I get 50VDC
        Means anything to you guys?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Originally posted by jeremykum
          Black = drain
          red = source
          0.480v
          reverse it, 0v
          That looks fine except "0V" is probably "OL" = meaning no voltage reading not 0V reading.
          • jeremykum
            • Feb 2012
            • 95
            • Malaysia
            I am not sure totally sure, but so far this didn't give indication of total failure though.
              On this board, this L shoud be L9801. Removed. Still 2.2V at A5V
              The filter cap for 13V register 0v. Circuit checked, not grounded.
              Q9101, should be the big N-Chan mosfet FDD7N25LZ, measured with DCA meter, seems working. Source and drain, one way register 11.2Mohm, the other way 0 (if continuity mode, no beeping).
              That 13V is generated by the same transformer that generate the 5V and other Voltages, and the cap I suggested to test the Voltage is right after the rectifiers for the 13V BEFORE the switch so it cannot be 0V unless the schematic does not match the board, that schematic looks to be made by reverse engineering so it i may not be accurate.
              • jeremykum
                • Feb 2012
                • 95
                • Malaysia
                #27
                I ordered a replacement board. Same codes, but rev number is 1.1 instead of 1.2 on the problematic psu board.
                All voltage is alive and within limits. However the power button on the tv would not fire up the tv. No backlight, nothing. I notice the main chip on the motherboard is slightly warm, I assume nothing is wrong.
                I tried disconnecting the mother ribbon connection to psu board. Switch on the mains, the led light up. Connect it back, and cannot power on.
                Any ideas?
                Is it firmware related?
                Anyway, the remote is not with me at the moment, already inform the owner to send it to me asap.
                • jeremykum
                  • Feb 2012
                  • 95
                  • Malaysia
                  #28
                  some updates
                  At this connector, those with voltage symbols all have the respective volt.
                  and...
                  Power On/Off - 3.50v
                  Pwm Dim - 0
                  BLU on/off - 4.85v
                    "Pwm Dim - 0" You will not get the backlights to be on with Dimming control at 0 V.
                    Turn the TV off, then put black probe on the chassis, Red probe on the Dim pin, then turn on the TV to see if there is any activity with the Dim control signal or not.
                    We also need the pictures of the whole back side of the TV showing all the boards.
                    BTW: These Voltages below, do they change state when power switch is toggle on and off?
                    BLU on/off - 4.85v
                    • jeremykum
                      • Feb 2012
                      • 95
                      • Malaysia
                      #30
                      BLU on/off - 4.85v
                      Those 3 voltages doesn't change when pressing the power on button.
                      • HABIBOU11
                        • Jul 2015
                        • 50
                        • ALGERIA
                        #31
                        Thank you
                        Хвала Аллаху, Господу миров
                          MSI Pulse 15 B13V Notebook 15 Specification for Upgrade or Repair
                          This specification for the MSI Pulse 15 B13V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 B13V boardview and 15 B13V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for MSI Pulse 15...
                          09-07-2024, 06:31 AM
                        • Tom41
                          USB chargers that give more than 5V?
                          by Tom41
                          I recently bought a portable label printer with a USB port that allows you to charge the internal battery. It comes with a USB-A to Micro-USB cable, but no charging plug. A sticker next to the charging port says "Warning! Do not use adapter with voltage over 5V!"
                          Thing is, are there any USB chargers that give out more than 5V, and in what situation would that be used? Just to be on the safe side I used a multimeter to measure my chargers - one is giving out 5.11V, the other is giving out 4.9V. The warning sticker suggests the printer doesn't have any overvoltage protection...
                          11-15-2025, 08:18 AM
                        • Phuong_Vu
                          Please help me, Please give me the gigabyte Z87p d3 boardview diagram
                          by Phuong_Vu
                          I need boardview gigabyte Z87p d3 to repair
                          whoever has please give me thank you very much
                          09-13-2025, 12:41 AM
                        • Rhaverz
                          Asus rog strix rtx 2060s a8g graphics card turns on and does not give video
                          by Rhaverz
                          Good afternoon friends, I have the same problem, the equipment turns on, when I connect it to the equipment and without connecting it to the HDMI or Display port with the integrated graphics of my equipment, the graphics can be displayed in the device manager with an error 43 but even if I try to update it "manually" it manages to remove the notice but it still doesn't work.
                          If I connect the graphic with the HDMI or Display port, the equipment turns on but it makes a long and 3 short beeps and does not give video
                          I thought that the BFDJ USB-C or MP8858GQ...
                          02-07-2023, 04:26 PM
