Issue with Samsung PS50c450 Plasma 50" no power up
  • edgimeno
    • Jun 2017
    • 15
    • Spain
    Re: Issue with Samsung PS50c450 Plasma 50" no power up
    No, if you mean the "heartbeat monitor" LED on the T-CON, it doens't light up at all at any time, looks like the board it 100% dead (either by itself or due to lack of some power, I don't know what PS voltages it depends on)
    • tw2005
      • Oct 2011
      • 6458
      Yeah, well I have the back off a 50c451 and with x y disconnected and ribbons also disconnected. I get a nice steady 1 sec heartbeat.
      Even with all ribbons removed from the Logic Ctrl board but with main connected to power and the power connected to the logic board it still gives a steady 1 sec blink.
      How about posting some pictures.
      And that guide i put up tells you the voltage and pins at the logic board. Have you looked at it?
      • edgimeno
        • Jun 2017
        • 15
        • Spain
        Yes I will try to take pics next time I open it up (I need someone to help me bring it up to the work bench )and also take voltages for Std-by, etc...
        • tw2005
          • Oct 2011
          • 6458
          I know the answer, no you have not looked at it(yet) 0 views recorded.
          • edgimeno
            • Jun 2017
            • 15
            • Spain
            If you mean the PDF you pointed to, yes! I downloaded it and saved it to have it handy later tonight if I have the chance to bring the TV to the work bench
            • Kjell
              Samsung Series 9 - BIOS issue
              by Kjell
              After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
              Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
              08-01-2025, 09:15 AM
              09-07-2024, 05:50 AM
            • lp20th
              Samsung Plasma TV Power Supply Issue
              by lp20th
              I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
              11-28-2023, 10:28 AM
            • vincentedel
              Samsung SyncMaster 740n Phase Control Issue
              by vincentedel
              I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
              I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
              04-22-2025, 12:33 AM
            • Manucsl
              QE65Q800TATXXC Samsung TV Issue
              by Manucsl
              Hello.
              My TV is a QE65Q800TATXXC Samsung TV.
              Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
              Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
              Any ideas to check would be very appreciated 😊
              After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
              02-19-2025, 07:47 AM
