Grundig 32VLE5500WG repair, no power, power mosfet
  • Chungalin
    • Jul 2014
    • 423
    • Spain
    Grundig 32VLE5500WG (same as 32VLE5500BG, only external color difference) 32" LED TV, all plastic, very cheap construction.
    It has a 19VDC 3.8A power adapter that seems OK, but no standby LED at all. With a laptop adapter I see that standby LED flashes, telling me that there’s something shorted somewhere. Put alcohol over main ICs and SMD caps, and first one burning is T1200 (not marked on PCB, and service manual doesn’t tell its name!!), SOT-669 package, "69100" marking. After some research, it’s a Nexperia PSMN069-100YS. It’s shorted.
    Since I don’t want to order this silly thing, I use my database to find that I have a IRF530NS with matching specs. It’s a much larger TO-263 but I have it at no cost.
    I’ve soldered Drain tab to PCB and wired Source and Gate pins. Not very beautiful, but no extra expenses, and it works.
    Original power adapter works OK once the TV is repaired. I guess it protected itself when detecting overcurrent.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • Thomas Smith
    Asus Tuf gaming fx506l no power, mosfet does not open
    by Thomas Smith
    Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
    Initial Symptoms:
    • The laptop has no power at all (no LEDs, no fan spin).
    • No 3.3V or 5V present on the board.
    • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
    Power Rail Checks:
    1. Charger input (FETs PKCH2BB)
      • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
    2. BQ24780S Charger IC:
      • VCC and ACDET are present.
      • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
      • Shunt resistor has 10Ω to ground.
    03-30-2025, 03:38 AM
    03-31-2024, 02:12 PM
