Panasonic TX-P42U30B with CN board TPNA5349AB
  • robertpearce4
    • May 2017
    • 4
    Can anyone please tell where I can get a Panasonic Part COZBZ0001812. The tiny 8 pin SMD has D86 93 NZ printed on the body (possibly 2 characters missing). Its a driver IC for a IGBT on a plasma scan board. Does it have a none Pansonic part (generic) ID?
  • flocko
    • Nov 2012
    • 1121
    Re: Panasonic Part COZBZ0001812
    I think the part you are looking for is a BD8693 IGBT driver that is fitted to Panasonic SC/SN boards.this would show a Panasonic part number of COZBZ001920. The other larger IGBT driver COZBZ001936 that are fitted to some boards would be a NJW4840 , Hope this is of help Flocko
    • robertpearce4
      • May 2017
      • 4
      Yes that looks right. I miss-typed the Panasonic number, it should of ended 1822 not 1812. Out with the heat gun now I can order replacement/s. Can you live fault-find on these boards...if you can keep them from shutting down....beyond static resistances checks?
      Thanks Flocko.
      • flocko
        • Nov 2012
        • 1121
        Please post with model and board numbers in the Tv repair forum,and search for more info on repairs, but also note that there are a lot of fake BD8693 ICs,only use ones that show the same markings as fitted by Panasonic (check photos if buying from eBay)
        • robertpearce4
          • May 2017
          • 4
          I think Q501 has gone U/S. The 47K emitter resistor has gone O/C. It's a B1HFPFA00001. The waveform on Q401/402 is all wrong. What is the replacement equivalent please?
          TV is a Panasonic TX-P42U30B CN board is a TPNA5349AB. Thanks for your support...I am a new to this type of repair...
          • flocko
            • Nov 2012
            • 1121
            Re: Panasonic TX-P42U30B with CN board TPNA5349AB
            Q501 marked Y3 = CPH5524-TL-E (transistor array) these should be replaced with the IGBT driver IC501 (BD8693) as a pair. You will find full details of how to repair and test this and most other Panasonic SN/SC+SS boards by using the forum search.
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              by sam_sam_sam
              After all of...
              07-13-2024, 08:14 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • dajoker
              Panasonic th-p50s10d - blinky red, SC board go boom
              by dajoker
              My old plasma died when one night recently. When I got to it it was giving a 3.3v sos (3 blinks).
              I chased my way through the PSU, and a board, with no results.
              Replacing a few bulged caps in the PSU, I eventually got to the SC board that had piles of shorts, a quick cheap replacement from china and the tv powers up again, except
              I only have the right half of the picture.
              Left half is completely blank.
              now the c3 board running this side of the screen has its 3.3 and 5v onto the buffer ic and its got the 60v, so that all seems good.
              all the other voltage rails...
              09-24-2024, 04:39 AM
