Changhong LED50YC2000UA
  • jose6326
    • May 2013
    • 707
    so i pulled this set from an electronics bin
    the panel works but the "ant in" connection is broken
    so i used an HD digital converter box with the a/v cables to connect it to the ports on the set to view basic tv channels
    the tv worked fine for a while then the sound when out and only one channel had sound
    maybe it was the converter box but i still want to replace the main board so i can connect an antennae or cable because i will be using it in my office as a monitor as well
    so my question is if someone can help me by identifying the boards on ebay if they will be compatible with the one from my set. i have always had good luck buying boards from ebay
    here is the link and pic the board i want to buy
    but there are differences in the board such as the amount of caps on the board. also the number on the ebay board is JUC7.820.00121165 HLS43C 2014-6-27
    i am posting pics of my board in the next post
  • jose6326
    • May 2013
    • 707
    Re: Changhong LED50YC2000UA
    here are the pics of my board
    JUC7.820.00095793
    HLS43C 2013-9-6
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      The numbers match the Hiitachi Main Board for an LE42H508A LCD set so an internet search may help you find a replacement. Also check that it says what LCD Panel it matches and compare to your panel number.
      • Dumah Brazorf
        • Jun 2013
        • 179
        • Italy
        Change that pcb mount F connector, it wont be too hard.
        • jose6326
          • May 2013
          • 707
          where can i order that part?
          • jose6326
            • May 2013
            • 707
            would these work?
            https://www.digikey.com/products/en/...=0&pageSize=25
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Just search for keystone f connector.
              http://www.ebay.com/sch/i.html?_odkw...r+SMD&_sacat=0
              The hard part is to find a SMD variant for that mainboard.....
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Hmm that digikey site is better , they look smaller though.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Isn't the F connector an integral part of the tuner module and not a separate item?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Might have a look at these: http://www.ebay.com/sch/i.html?_from...5543+&_sacat=0
                    • jose6326
                      • May 2013
                      • 707
                      that is what i was thinking
                      but when i look inside of the metal housing it looks like it was only soldered at one contact point on the board
                      i will remove the housing and take a picture later tonight
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Good idea. If the F connector is not moulded into the tuner casing then it looks as though the suggestions given above would work.
                        • jose6326
                          • May 2013
                          • 707
                          so i removed the housing
                          looks like there is only one spot to solder in the rf connector
                          now i need to figure out which connector to buy ?
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            So it does look as though one shown on the ebay link above will do the job for you.
                            NEW RCA 215543 TV TUNER RF CONNECTOR CHASIS MOUNT TEFLON CENTER REPAIR WONT MELT
                            • jose6326
                              • May 2013
                              • 707
                              i ordered the 10pcs
                              do i need to reinstall the housing?
                              • Dumah Brazorf
                                • Jun 2013
                                • 179
                                • Italy
                                I think is better to reinstall it to avoid possible interferences.
                                Maybe you can fix the new connector to it with a couple of thin washers and nuts.
                                • jose6326
                                  • May 2013
                                  • 707
                                  the repair worked
                                  cost me .25 cents since i found the rf connector at Radio shack and they are going out of business
                                  thanks for the help
                                  • jose6326
                                    • May 2013
                                    • 707
                                    so i used it as my 4th monitor in my office
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • Hakuu
                                      by Hakuu
                                      Hi There,
                                      More Details
                                      TV Model - LG OLED77G1PUA
                                      07-12-2023, 02:37 PM
                                    • gizmo1990
                                      What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                                      by gizmo1990
                                      I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                                      The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                                      10-21-2024, 08:02 AM
