BauhnvAC-46FZ screen half black half green
  • maxvalutech
    • 804
    • australia
    Found this set laying on kerbside. Cleaned it up fitted AC cord and had a look to find lhs screen black and rhs green with about 4" vertical panel in styrated lighter green. Selected menu and it came up as did no signal panel all over the screen despite continued fault. Research indicats that tab bonds are usually the problem but in this case may well be faulty tcon. Thoughts?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: BauhnvAC-46FZ screen half black half green
    So you had good menu over the fault?
    • maxvalutech
      • 804
      • australia
      Re: Bauhn AC-46FZ screen half black half green
      Yes mate and now have set upright as I had to fashion a stand for it. Green is problem side with styrations etc black on rhs from front generally OK but there is a horizontal band about 4" wide a bit darker which goes right across top of picture. Tried to upload pics but no go - will try again.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Ya a picture is worth a thousand words. Especially in this case.
        • maxvalutech
          • 804
          • australia
          Attempting picpost again...
          • maxvalutech
            • 804
            • australia
            Sorry for reflections which I hadn't noticed until files transferred to laptop. So take no notice of the white areas and note that red colour comes up as yellowish on lhs of screen.
            • maxvalutech
              • 804
              • australia
              One final pic
              • dskall
                • Oct 2016
                • 2905
                • usa
                You tried cleaning and resetting t-con cables?
                • maxvalutech
                  • 804
                  • australia
                  Sorry yes took tcon out cleaned input both ends and reseated a few times and also did screen outputs.
                  • maxvalutech
                    • 804
                    • australia
                    From my very limited experience I feel there may be two faults in this set - tcon the split screen and panel the other more minor issues. If I can get a tcon at reasonable price and I was right I have rellies with a " shack in the hills" which is only visited every 4/6 weeks and where due to isolation/intruders nothing of worth can be left.
                    This set could then prove ideal for where after a hard days trail riding a footie match could be watched over a few beers.
                    • maxvalutech
                      • 804
                      • australia
                      Well after many weeks away the replacement tcon was here when I got back. Fitted it but little change but then noticed only a third of the screen was green and wiggling strap for lhs brought up a lot of variations. In the interim did read a post where it was recorded similar connection may need 50 or so attempts to get it right so working on that and after many many tries got a reasonable picture! Set the strap in connector with a touch of glue. Now to see if it lasts
                      • maxvalutech
                        • 804
                        • australia
                        Well they say ignorance is bliss so I should be very happy but no I am just flummoxed. Brought this set in to tune all local channels but on first attempt only got 16 whereas should be 25 tv and 6 radio. The screen was usual snow until 50 percent of scan then goes solid black for dtv but the dreaded green was back!! And this showed up in the programs with green styrations on dark colours and purplish highlights on skin tones. Ok that was original problem. But here's the rub I decided to do a reset (no remote) and this too saw green problem but as I wasn't happy with reception of some channels I retuned again and lo no green came up during that scan and there is now no sign of any problem in picture reception! The green problem has gone! How can that be - what is relationship between tuner and t-con for this to happen when only one side is affected?
                        • maxvalutech
                          • 804
                          • australia
                          My thinking now is that the green problem went away of its own accord as set warmed up from being used. kept it on using various channels for a couple of hours with no problems showing up again.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            You will probably need to cool things on t-con / mainboard to try to locate problem if it comes back
                            • maxvalutech
                              • 804
                              • australia
                              Yes your right and I do have a can of air now. The set has been put aside to attend a bit later. With the fitting of lhs strap to connector I gained an impression that a little twist in that strap needed to be just right for the picture to come good. Cold to warm could affect that touchy situation and we have just had a few cold winter days.
                              • maxvalutech
                                • 804
                                • australia
                                Finally got back to this set and the original problem again evident. Decided on drastic measures so pulled it apart been couldn't get to where tcon ribbons (2) feed into another board to screen. Too much to disassemble so used pliers to bend chassis frame up enough to release connector for ribbon on bad side. Gave the connector and ribbon a good clean and finally some success as all came good. This was a wall mounted set and my suspicion is some moisture got in probably when owner cleaning it. Our area is a maritime environment and corrosion a problem.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  Well good to hear. Hopefully it won't come back
                                  • Raulnn
                                    TD Systems K50DLG12US half black and half white screen
                                    by Raulnn
                                    good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                    By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                    01-20-2024, 04:49 PM
                                  • HTR-Informatique
                                    by HTR-Informatique
                                    02-09-2025, 06:51 AM
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • kca
                                    by kca
                                    Hello all ~
                                    08-31-2025, 06:38 AM
                                  • VcemPzd
                                    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                    by VcemPzd
                                    Hello everyone !
                                    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                    04-28-2025, 10:14 AM
