Identifying Vestel malfunction - shadows with wrong colors on the screen
+ More Options
Posts
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    • Bulgaria
    The TV is Crown CCT3207W(Vestel 17MB08P-5 chassis)
    The problem is with shadows on the screen with wrong colors, that appear usually if there is a high contrasting image on the screen, including gradients. I am attaching a pictures. What do this artifacts mean? Look at the blue shadows, that appear on the parts of the image, where there are gradients of certain colors. Sometimes the shadows are blue, sometimes red - depends of the background color...
    The problem is not with the image source. I've tried a STB on the SCART and another STB on the RCA inputs..
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Identifying Vestel malfunction - shadows with wrong colors on the screen
    Gamma IC on the tcon ?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      If you do not have the skill to replace the Gamma IC on the T-CON Bd, just replace the T-CON Bd.
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        • Bulgaria
        Why the shadows did not appear constantly?
        • dskall
          • Oct 2016
          • 2905
          • usa
          Can we get close up picture of t-con
          • France_53
            Vestel tv, how to flip the image?
            by France_53
            Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
            05-12-2024, 05:22 AM
          • FlailingEngineer
            Help with Bush Tv (Vestel 17mb95m Mainboard)
            by FlailingEngineer
            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
            05-31-2023, 06:52 AM
          • massimomax
            Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
            by massimomax
            Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende piΓΉ,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
            spero che qualcuno puΓ² averlo per riprogrammare eprom. grazie
            Post in English !!!
            I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
            02-28-2025, 07:27 AM
          • silikon77
            Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
            by silikon77
            Hi!
            Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
            Found some advices watching youtube nad came up with this:
            It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
            I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
            See attached picture.
            I tried a few combinations to block individual clock...
            01-02-2025, 02:26 PM
          • Adenitz
            Troubleshooting Vestel TV, has standby, but cannot turn ON
            by Adenitz
            I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
            Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
            Both boards are shown in the attached photos.
            What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
            12-27-2023, 03:43 AM
