SHARP LC70le600U 1 at plug in.
+ More Options
Posts
  • Redjess
    • Feb 2016
    • 54
    • Usa
    Ok, i bought what is supposed to be a new power board, because when I 1st got this tv, it had no power that i noticed, whatsoever. So, got the powerboard, and now I notice the little boomerang/chevron a the bottom of screen in bezel, lights up 1 blink as soon as I plug in a powersource. Still nothing else. I never noticed if it lit up previously but now does. Anyway, the screen or tv still doesnt work. Is the mainboard going to fix it? How can i force power on? Ive tried the channel up volume down power button simultaneously, at different times, different variants all to no avail. Ive read somebody refer to a jumper at the 5v to the PSON. I dont really know what that is, but BrainLikeSponge.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: SHARP LC70le600U 1 at plug in.
    Need good clear straight on pictures of back of tv with cover off and each board.
    Need voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
    Format:
    Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
    1 - XXXXXXX - XXv - XXXv
    2 - XXXXXXX - XXXv - XXXv
    3 - XXXXXXX - XXXv - XXXv
    4 - etc.
    • Redjess
      • Feb 2016
      • 54
      • Usa
      Ive never used a multimeter, i have a cheapy centech brand one. Any and all help is appreciated. I do have a new grand Simpson 8a meter, but cant find wires that arent 20bucks or more for it (reverse banana plug style). Pics within the hour.
      • Redjess
        • Feb 2016
        • 54
        • Usa
        Quick shots
        • dskall
          • Oct 2016
          • 2905
          • usa
          Without voltages we can't do much.
          • Redjess
            • Feb 2016
            • 54
            • Usa
            Im gonna get it as soon as i can, i got too many kids in my house and the taco joint forgot my burrito in my takeout
            Had to go back to get it.
            • Redjess
              • Feb 2016
              • 54
              • Usa
              Heres the plugs, but I'm not yet sure how to check, so ill be youtubing it a bit.
              • Redjess
                • Feb 2016
                • 54
                • Usa
                Yellow board is powerboard, green board is main board. How do I go about testing?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Just like post 2
                  • Redjess
                    • Feb 2016
                    • 54
                    • Usa
                    I got a new main board, it turned on finally, but was cracked. So its currently available for parts.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Screen cracks can be hard to see
                      • Redjess
                        • Feb 2016
                        • 54
                        • Usa
                        Yea, i was careful to look at it, but since this screen had a screen in front of lcd, i couldnt see until it actually turned on. Bummmdd
                        • sew333
                          Can i plug pc on this apartment with older fuse box?
                          by sew333
                          Hello. I will be buying new apartment to live. But fuse box is older. Not the newest.
                          And my question. It will be fine to plug pc in this new apartment with that fuse box,i think it is aluminium,right?
                          PC WILL BE: Rtx 4090,14900K,1600W PSU
                          It looks like this ( screen from internet ). Looks like this,not sure i dont take a pic from there. Can i plug pc with that one?
                          screen of this:
                          room:
                          Someone said this to me.
                          1
                          "I would get advice from a local electrician...
                          03-29-2024, 05:37 PM
                        • Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                          by Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                          03-15-2024, 09:37 AM
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
                        • Per Hansson
                          Repair of Sign WiFi Smart Plug PCB: SA-P302A v1.2 due to bad caps - with schematic
                          by Per Hansson
                          I have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
                          The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
                          The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
                          As I find linear high voltage regulator designs interesting I drew up the attached schematic...
                          12-23-2023, 06:20 AM
                        • gavenb
                          Sharp LC-80LE661U 80 inch
                          by gavenb
                          Hi folks!
                          I have a LC-80LE661U that had some interesting issues.
                          Initially, it would come on and show the sharp logo and would show normal static before shutting off.
                          I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
                          11-12-2023, 02:05 PM
