Polaroid TLX-04244B Image Quality Question
  • jwillifixit
    • Apr 2017
    • 113
    • usa
    So I "acquired" one of these for free the other day and it's working but has a pretty bad picture. I put a blu ray movie to it using HDMI and skin tones look reasonable but the shadows / darker areas not so much... Attached are two images. Left on each is with all settings at 50% and right is with contrast cranked to 100%. I noticed on the settings menu that there's all sorts of pre-set (cinema, soft, bright) and the "bright" seems to look the "best" but is still off.
    I'll get the back off and begin a visual inspection tonight but in the mean time had a general question about what area the signal processing would go bad like this.
    Thanks as always for your guidance.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Polaroid TLX-04244B Image Quality Question
    Gamma problem. Pretty sure your t-con board has the as-15 chip which is a common failure. You can replace chip or t-con depending on your skill level.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      I've had a similar issue with a low cost set with virtually the identical display as you show above. Changed the TCON but made absolutely no difference.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Well he could post his t-con voltages and we could run them through the spreadsheet to confirm.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          This panel used is known for tab bond and gamma Ic failures. Test the gamma Ic if its good tab bond issue.
          • jwillifixit
            • Apr 2017
            • 113
            • usa
            I'm going to give it a go with replacing the AS-15 I think. I'm new to all this but loving the feeling of working with you all to troubleshoot and fix. Scored a nice 47" for the cost of replacing a voltage regulator ($1.27 usd)... what a thrill!!!
            So I read the hot air station threads and have one on order as well as an illuminated mag lamp (my eyes aren't what they used to be).
            I'll follow through tonight on checking the voltages and post. I saw that calculator excel sheet and would love to get to a point where I understand it. ;-) I mean I get what it's doing just don't know what the values are all about.
            • jwillifixit
              • Apr 2017
              • 113
              • usa
              Okay I hope I've got this right... see close up of connector. I marked up what seems to be pin 1 and it looks like they go back and forth from side to side instead of up one side and down the other...
              01 = 12.01
              02 = 12.01
              03 = 12.01
              04 = 0.007 (there's no wire there?)
              05 = 0.007
              06 = 0.007
              07 = 1.491
              08 = 1.115
              09 = 1.531
              10 = 1.144
              11 = 1.443
              12 = 1.146
              13 = 0.008 (there's no wire there?)
              14 = 0.008
              15 = 1.279
              16 = 1.332
              17 = 1.495
              18 = 1.098
              19 = 1.511
              20 = 1.127
              21 = 1.517
              22 = 1.128
              23 = 1.463
              24 = 1.170
              25 = 0.009
              26 = 0.009 (there's no wire there?)
              27 = 1.247
              28 = 1.302
              29 = 1.503
              30 = 1.118 (No connector over these)
              31 = 0.003 (No connector over these)
              32 = 0.003 (No connector over these)
              33 = 3.28 (No connector over these)
              34 = 0.001 (No connector over these)
              35 = 3.31 (No connector over these)
              36 = 3.30 (No connector over these)
              37 = 0.001 (No connector over these)
              38 = 0.001 (No connector over these)
              39 = 0.001 (No connector over these)
              40 = 0.001 (No connector over these)
              Pic's are:
              Overview
              Close ups of main board including mark up of connector and what I think ya'll are calling the AS-15... tell me it's not the one under the heat sink rubber thing on the Control board please (anyway that one had no markings on it).
              • dskall
                • Oct 2016
                • 2905
                • usa
                Last picture t-con board. Upper right under brown heat sink material. What is that chip number? Also right there you have about 22vgma test points. Need all those in order. Or you can plug them in here
                • jwillifixit
                  • Apr 2017
                  • 113
                  • usa
                  As15-f
                  0831cg
                  b8516257
                  1 = 14.05
                  2 = 13.90
                  3 = 13.75
                  4 = 11..07
                  5 = 10.90
                  6 = 9.95
                  7 = 9.40
                  8 = 9.13
                  9 = 11.70
                  10 = 12.00
                  11 = 6.85
                  12 = 6.20
                  13 = 6.10
                  14 = 5.90
                  15 = 4.41
                  16 = 4.16
                  17 = 3.83
                  18 = 2.86
                  19 = 2.19
                  20 = 0.53
                  21 = 0.43
                  22 = 0.29
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    Looks to me like a bad gamma chip. Readily available if you have the skill to replace it.
                    • jwillifixit
                      • Apr 2017
                      • 113
                      • usa
                      I don't as yet have the "skill" but I have the desire to acquire it through practice and I've quite a few scrap boards around here so... I've got a hot air 2 in 1 unit on the way and will get the IC on order too. I assume the only important part of the numbers on the part is the AS15-F and the rest of it is date/lot code info. As long as I order an F and not an HG etc. I'll be fine?
                      EC5575-F AS15-F TQFP48 14+1 lead-free
                      EC5575-G AS15-G TQFP48 14+1 Green Package
                      EC5575-FR AS15-F TQFP48 14+1 lead-free; (R) : Tape & reel
                      EC5575-GR AS15-G TQFP48 14+1 Green Package; (R) : Tape & reel
                      EC5575-HF AS15-HF TQFP48 14+1 lead-free ( H )
                      EC5575-HG AS15-HG TQFP48 14+1 Green Package ( H )
                      EC5575E2-F AS15E2-F TQFP48 14+1 (pin40 is Vcom-) lead-free
                      EC5575E2-G AS15E2-G TQFP48 14 channel (pin40 is Vcom-)Green Package
                      EC5575E2-HF AS15E2-HF TQFP48 14+1 (pin40 is Vcom-) lead-free ( H )
                      EC5575E2-HG AS15E2-HG TQFP48 14 channel (pin40 is Vcom-)Green Package (H)
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        I screwed my first attempt up. Blew off one of the resistors. I definitely recommend practicing on scrap boards.
                        • jwillifixit
                          • Apr 2017
                          • 113
                          • usa
                          I added the "optional information" to the excel file. I couldn't find a test point for VCOM but did find VCOM2.
                          It looks to me like this chip is a Fail but I'm having some issues with the sheet and wonder if others are seeing this same thing. See images...
                          Summary doesn't populate with a Pass or Fail just shows a #Ref
                          Detailed Results shows quite a few #Ref and #Value
                          Thanks... I'm sure looking forward to getting my hot air station.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Your basic voltages look good but your gamma voltages are bad giving you the bad picture. If you scroll to top of page it will give results. As they say this is not 100% accurate
                            • jwillifixit
                              • Apr 2017
                              • 113
                              • usa
                              I've been lucky so far with getting units that had simple to fix common problems. For example the 47" Vizio LCD that needed a little surface mounted AMC1117 voltage regulator replaced. I figure it's not that often where the only problem is the simple, inexpensive one and you're done but I'm hoping to go 2 for 2 with this one.
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                What fun would it be if they were all easy
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  Originally posted by jwillifixit
                                  As15-f
                                  0831cg
                                  b8516257
                                  1 = 14.05
                                  2 = 13.90
                                  3 = 13.75
                                  4 = 11..07
                                  5 = 10.90
                                  6 = 9.95
                                  7 = 9.40
                                  8 = 9.13
                                  9 = 11.70
                                  10 = 12.00
                                  11 = 6.85
                                  12 = 6.20
                                  13 = 6.10
                                  14 = 5.90
                                  15 = 4.41
                                  16 = 4.16
                                  17 = 3.83
                                  18 = 2.86
                                  19 = 2.19
                                  20 = 0.53
                                  21 = 0.43
                                  22 = 0.29
                                  pins 9 and 10 look like the faulty area i have never changed one of these ics yet but have a few spare tcons so may have a practice as i do have a hot air station etc
                                  • jwillifixit
                                    • Apr 2017
                                    • 113
                                    • usa
                                    As can be seen in post #9 there clearly were markings on that IC... what kept me from seeing them was the adhesive from the rubber heat sink pad.
                                    Here's a question - the surface of that pad that was "glued" to the IC is now not smooth and flat and also has no "stick" left to it. I assume I can use the thing on the replacement IC by simply turning it over but what type of adhesive should be used to bond it to the IC?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      heat sink compound like used on computer cpus? im not sure but dont see why it wouldnt work
                                      • jwillifixit
                                        • Apr 2017
                                        • 113
                                        • usa
                                        The first reason that comes to my mind is "gravity". Unless this pad is being held in place by compression with the cover shield I'd say it would simply slide off the IC once the TV is stood up.
                                        I think it needs to be some kind of contact cement I just wasn't sure if it needed to be anything "special".
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
