Lg 50pq3000
  • azza1234
    • Nov 2013
    • 124
    • united kingdom
    Lg 50pq3000
    Just been given a lg 50pq3000 plasma with a typical plasma fault where the tv just continuously clicks I have checked the boards for any obvious faults but failed to find any when I plug the tv in the red light comes on for a second then just keeps clicking are there any known faults with this set? No light from the screen etc
  • azza1234
    • Nov 2013
    • 124
    • united kingdom
    Re: Lg 50pq3000
    I've unplugged the ysus and still the same and the same with zsus and the same again with the main board so this has pointed to the power supply board i will get pictures and voltages and post them later
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Re: Lg 50pq3000
      Psu switching Ic for lower rails forgot PN, just change Psu if you dont know what your doing.
      • azza1234
        • Nov 2013
        • 124
        • united kingdom
        Re: Lg 50pq3000
        Where's the fun in just replacing i would like to try repair as new power supply is £100
        • Techstar
          Tv Restoration
          • Dec 2012
          • 122
          • United Kingdom.
          Re: Lg 50pq3000
          Check diode D352 on the power supply board it may be short circuit.
          i had this fault once before on this model.
          • ArMaaN376
            Samsung PS51E550 Plasma TV
            by ArMaaN376
            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
            Opened TV cover & observed foll
            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
            How to confirm Y -Buffer board...
            06-19-2024, 04:05 AM
          • KYBOSH
            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
            by KYBOSH
            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
            No picture but you hear the TV static (white noise) playing loud and clear.
            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
            But it seems they didn't get too far and just left it.
            When I first took a look I was amazed at how pristine the inside looked.
            Its as if the TV had been in a time capsule.
            Caps looked like they were just pulled off the self.
            Copper coils had no sign of corrosion on...
            02-01-2023, 11:10 PM
          • alltvrepairs
            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
            by alltvrepairs
            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
            Any one met this problem in the past?...
            10-08-2025, 07:34 AM
          • chazh
            LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
            by chazh
            This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
            I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
            The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
            09-01-2025, 08:56 PM
          • porfyriadhs
            Samsung Plasma PS51D6900DS Bootloop
            by porfyriadhs
            Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
            Thanks a lot !!
            10-19-2023, 11:31 AM
