LG 42ls570T
  • speedypro
    • Feb 2013
    • 561
    • United Kingdom
    LG 42ls570T
    This is my personal TV. It works for few minutes then the back light goes out, sound still present. Using a torch, I see the video. Restart the TV, backlight comes on then the cycle repeats but it stays on on many restarts.
    Could it be a backlight strip or the board itself? Sometimes left of the screen is black. But if one backlight has failed, all should as it's in series?
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 42ls570T
    This TV only uses one backlight strip running down the left hand side if I remember correctly.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Re: LG 42ls570T
      One of the backlight LEDs could be failing as a short. therefore the strip would remain lighting but will pull a little more current (amps) and will shut down the Driver. Leaving the rest of the circuits running with no backlight.
      • speedypro
        • Feb 2013
        • 561
        • United Kingdom
        Re: LG 42ls570T
        Yes, when a section looks dark, now I see why.
        Thanks for that. I hope to find it as if I power off/on the tv, it works as normal but after few minutes, its gone again. I'll order few leds and replace all. Thanks.
        What is the voltage for these leds? 5v/6v?
        • Sucher
          • Mar 2014
          • 9
          • United Kingdom
          Re: LG 42ls570T
          Thats not like that really. The current in the whole circuit stays the same, as its a series connection. This particular LED bar consists of 6 circuits ( loops) with 6 feedbacks to Dimming controller( AUO K301-29 chip). If one led diode goes short theres higher voltage drop across that diode which in turns leads to higher voltage voltage supply of this loop, the chip senses that and shuts down the entire supply. If the diode goes 'short' it doesnt mean its resistance is zero( like a shorted transistor) the diode wont light up, the current in this circuit is the same but its resistance will increase. However if you removed that diode snd put the solder blob on it( to shorten it) the led driver would inteligently reduce the drive voltage to match it with the numbers of leds in this circuit. This is PWM supply- not purely DC, the amount of current is controlled by PWM pulses.
          Paul
          • triplefour
            by triplefour
            09-13-2023, 10:43 PM
          • edugimeno
            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
            by edugimeno
            Hi There!
            I'm trying to help my friend who owns a restaurant be just bought.
            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
            It's stuck using, I guess, the 2 sided tape that comes with the strip
            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
            09-05-2024, 09:34 AM
          • DanPoka
            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
            by DanPoka
            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
            02-15-2025, 05:05 AM
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • DXseekerMO
            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
            by DXseekerMO
            Hello everyone!
            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
            Yes
            0%
            1
            All backlight strips are the same quality
            0%
            1
            No
            0%
            0
            12-16-2021, 03:58 PM
