Samsung UN60ES7150F 60" LED turns ON then OFF.
  • mattpd
    • Oct 2012
    • 301
    I have a un60es7150f that I am trying to repair.
    When you turn it on it clicks, LED flashes 5 times, the screen turns on with a VERY faint back light but no display.
    It stays this way for about 5 seconds and then shuts it self off.
    It then goes into a loop of trying to turn on, showing the faint back light, and then turning off. Funny thing is, it continues to do this for about 30 seconds after you unplug it.
    ShopJimmy had a power supply repair kit, so I tried it. It didn't help.
    I also tried a new TCON.
    All voltages at the main board appear to be OK.
    I'm thinking it's either the main board or maybe the LED back lights are bad...
    Any idea?
  • fberni
    • Oct 2014
    • 28
    Re: Samsung UN60ES7150F 60" LED turns ON then OFF.
    hi try to disconnect main board and plug power supply but leave back lights plug into main power supply you will see back lights do the same problems sound like I have back led lights
    • dskall
      • Oct 2016
      • 2905
      • usa
      Need good clear straight on pictures of back of tv with cover off and each board.
      • mattpd
        • Oct 2012
        • 301
        Sure, when I get home.
        It only contains a power board, main board and TCON.
          Power supply board P/N? BN44-????????
            09-07-2024, 05:50 AM
          • thetonywarren
            Samsung un32j5205af turns on, but needs to have power disconnected to power back on
            by thetonywarren
            SAMSUNG UN32J5205AF
            Wierd issue. Set turns on, works as normal, then turn off, and when you try to turn back on, it wont. The backlight comes on, but doesnt boot up. You need to disconnect power supply from back, then reconnect it, and then the set works again. somewhat annoying issue.
            Where to start? I can provide any videos or pictures needed to troubleshoot.......
            11-15-2022, 09:23 AM
          • Egidio85
            Samsung UE55F8000SZ Turns on and off immediately
            by Egidio85
            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
            This defect happens continuously, hearing the classic click of the relay every time.
            Power supply board BN44-00636B
            disconnecting the mains and lamps from the power board always causes the same problem.
            Is it normal that without anything connected this power supply turns on and off cyclically?
            any suggestions on what to check?
            thanks in advance
            03-11-2025, 12:45 PM
            09-06-2024, 11:40 PM
