Insignia NS-40DR420NA16 no power
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Insignia NS-40DR420NA16 no power
    It's hard to believe you would get two bad power boards. Three if you count yours with something as obvious as bad standby voltage. I cannot think of anything else but bad power supply. Standby is pretty simple. It always needs to be there and steady when plugged in.
      May be he should ask the seller to check the 3.3V that he has to see they have stable 3.3V on his stock boards.
        https://www.badcaps.net/forum/attach...8&d=1493049185
        Q202 looks to be switched power MOSFET for providing the switched 12V.
        U201 (P/N????) looks to be for buck converter to produce 3.3v
        • Daveleone
          • Apr 2016
          • 267
          Before we move on...just to make sure I'm not being a complete idiot, I uploaded a video of me testing the 3.3v pin on CON2. Video shows power cord plugged in, CON2 connector, ground of voltmeter attached to chassis, voltmeter test lead plugged into the 3.3v pin of the cable coming from CON2, and fluctuating voltage reading on voltmeter (yes, I know my voltmeter is complete garbage, but it generally works for testing voltages ).
          https://tinyurl.com/mw3q3bu
          Let me know if I'm stupid. If not, I'm ready to start testing other components on the power supply.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Voltage looks to be cycling on and off. Maybe going into protection mode.
            • Daveleone
              • Apr 2016
              • 267
              Ok, rather than try to fix someone else's problem I'm going to return both of these (defective) power supplies to the seller. I'll buy one from another seller and give you guys an update. Stay tuned!
              Thanks again for all the help.
                https://www.badcaps.net/forum/attach...4&d=1492990844
                Your original board: Did you check D208, 209, 210, another one close to those 3, and another one that is mounted in the heatsink at the bottom right of the board. Also check or replace the two startup/running caps C102, C10? at the bottom left corner of the power transformer T200.
                • Daveleone
                  • Apr 2016
                  • 267
                  Update on this TV. I bought another replacement power supply off eBay, this time from electroparts_warehouse. Popped it in and the TV works great.
                  Thanks for the help and advice, everyone!
                    Glad to hear that you finally get the good power supply. I would rate those people that sell boards and claimed that they are tested good rate those sellers as FALSE CLAIM.
                    • Daveleone
                      • Apr 2016
                      • 267
                      Yeah, what I did was I rated them Positive and in my Feedback I said "Board didn't work, but seller refunded my money in full," because they did give promptly me back ALL my money, including the shipping. But at least this way if someone looks at their feedback they can see that the boards they supply don't always work as they said they do.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                        03-31-2024, 02:12 PM
                        07-01-2024, 06:34 AM
                      • JimBanville
                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                        by JimBanville
                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                        09-13-2023, 07:21 AM
                      • Babbar
                        by Babbar
                        04-12-2024, 01:12 AM
