Sharp Aquos LC-46LE810UN Power Issue
  • omagnavox
    • Apr 2017
    Hi All,
    I've managed to find the service manual for my TV and according to it, the blink pattern refers to:
    Power PWB failure Flashes twice Flashes 3 times Power supply error 3 (*2) D3.3V error
    and
    D_POW Digital 3.3V failure. Flashes fast 3 times DET_D3V3(36pin)failure (L). Digital 3.3V is not applied. If error is detected during start-up or operation, the power is turned on again by polling.
    I've unplugged my TV for a while and turned it back on with the remote but still getting the blinking pattern.
    What would need to be repaired or looked at in order to resolve this issue?
    Any help would be appreciated.
    Regards,
    Stanley
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sharp Aquos LC-46LE810UN Power Issue
    Are you able to attach the service manual?
    • omagnavox
      • Apr 2017
      Here it is I think...
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Unfortunately it doesn't appear to offer any more information than you have already supplied and no circuit diagram to look though.
        Have you checked you have all the output supplies from the power supply when you switch on.
        Edit
        What are the part numbers of IC2702 & IC2703
        • 10switches
          • Aug 2017
          I have recently acquired a sharp LC-70LE640U with the same D_POW error, DET_D3V3(36pin) failure. Digital 3.3v is not applied. Ive done the error bypass so the chevron doesnt blink anymore, but the tv will not power on. The screen will not light at all, no information to be seen even with a flashlight.
          so I guess the question is how do I apply 3.3v?
          Ill also add that Im not too anxious to attempt measuring things with voltages 90-140.
          • cajoeg
            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
            by cajoeg
            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
            02-10-2025, 04:01 PM
          • claytongarcia
            Issue with Sharp LC-42SB45U
            by claytongarcia
            I recently got a model Sharp TV, and I've noticed that the green power LED is flashing without any specific pattern. Additionally, there appears to be no voltage coming from the power board. I haven't observed any leaking or bulging capacitors, although the top of the larger capacitor doesn't seem to be perfectly flush with the jacket—if that makes sense.
            Has anyone dealt with this issue before?​
            03-10-2025, 07:27 PM
          • SONY_E-WASTER
            Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
            by SONY_E-WASTER
            Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
            The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
            then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
            does...
            12-26-2021, 05:46 PM
          • Egidio85
            SHARP LC-40LE814E does not turn on 2 flashes
            by Egidio85
            hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
            the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
            reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
            now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
            to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
            07-21-2023, 11:49 AM
          • sefoster
            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
            by sefoster
            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
            11-20-2022, 09:29 AM
