Vizio E502AR LCD television powers on, then shuts off with a bright VIZIO
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    This is one headache of an LCD. If anybody else is trying to get into one of these things, the stand has to be unscrewed from the bottom and removed before the back panel can come off .
    Anyway, the reason I've cracked into this thing is because it powers on and displays the splash screen, but then the panel and backlights shut off (nothing on screen at all; I checked with a flashlight) after a couple seconds, at which time the VIZIO at the bottom lights up white very brightly. It stays this way until the power button is pressed again, at which point the cycle repeats once more (brief display of splash screen, bright VIZIO).
    Do these models shut themselves off like this if the backlights are bad? If not, what would likely be the problem? What does the bright white VIZIO mean?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vizio E502AR LCD television powers on, then shuts off with a bright VIZIO
    Have you tried disconnecting the main board and bringing up the leds to ensure you don't have a led fault.
    • dskall
      • Oct 2016
      • 2905
      • usa
      I believe these do suffer from eeprom problems.
      • SurrealMustard
        • Jan 2015
        • 487
        Mainboard and backlight troubleshooting
        I hadn't. Would it just require the jumpering of some connections on the power supply in order to do this?
        I saw a video of that on YouTube, but wasn't sure if it applied to this model as well. If the backlights check out, I'll have to explore that more closely.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          With the main board disconnected some power supplies will bring on the backlights when powered up otherise you will need to jumper using 1K resistor STBY_3.3V to PS_On pin and possibly a second 1K from STBY_3.3V to BL_ON/OFF.
          • SurrealMustard
            • Jan 2015
            • 487
            Mainboard replacement fixed the problem!
            Mainboard was indeed the cause of the issue. Everything is back 100% after replacing it.
            • stevebardocz
              • Oct 2017
              My grandparents TV has the exact same problem. We tried holding down the power button for 60 seconds from a youtube posting recommendation after unplugging it, then plugging it back in, but that didn't work. It sounds like it might have a bad board. What would have caused this? Power surge? Drop in voltage? It's behind a surge protector. It was working just fine, we plugged in a coax cable from a VCR/DVD combo so they could watch something since their cable was out, watched the intro on the DVD, then shortly after it powered off and started doing this cycle every time we turn it on. It stays on for about a minute - then the remote stops working, the unit turns off, and the light turns on the front lights up brightly again. Turn it on with the remote or the button on the TV, and it does the exact same thing. I could see the board fixing it but it seems like it's a firmware issue that's causing the problem. Maybe they are having power issues that are causing their electronics to fail? Their cable went out almost a week ago and they've replaced two cable modems and two DVR boxes. So I'm wondering if they're not dealing with power issues.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                I would do the test as in post #5 and post the results
                • Garret Matt.
                  VIZIO (V555-H1) Television with odd cascading display fault
                  by Garret Matt.
                  I'm working on a Vizio Model V555-H1 that displays a cascading series of horizontal lines when first powering on. These lines appear to be in the shape of the Vizio Logo and descend until reaching the logo before resetting to the top and continuing their descent. I have reseated my TCON board and dusted connections but still have this fault displaying. I'm familiar with vertical lines but this one is a new one for me. My research into this problem hasn't yielded results as keyword searches point back to vertical line problems.
                  Anyone have any recommendations? I...
                  04-04-2025, 02:56 PM
                • lowpost99@gmail.com
                  Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                  by lowpost99@gmail.com
                  I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                  09-03-2024, 02:57 PM
                • csmith
                  Vizio D50u-D1 Powers up no picture
                  by csmith
                  I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                  Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                  supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                  issue. Set will power up with remote but not power off....
                  07-11-2025, 11:52 AM
                • JaquesPratt
                  Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                  by JaquesPratt
                  I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                  This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                  07-16-2024, 01:04 AM
