Samsung TV LE32M87BD image issue, turns off by itself, works perfectly after warm up
  • Leplus
    • Apr 2017
    • 47
    • Spain
    #41
    Re: Samsung TV LE32M87BD image issue, turns off by itself, works perfectly after warm
    Originally posted by dskall
    Well looking at them isn't only test. Would need to check esr on them. Short of actually testing them is replacing them.
    Well, I have another 1000uF 16V available, Which one would you try? XDDD The yellow or another on the board? xD
    I don't have esr meter in circuit and my meter if I desolder them is up to 200u
    • finntricky
      • Jan 2014
      • 449
      #42
      Originally posted by Leplus
      Nah, I changed both caps but the problem remains, same behaviour like in the videos.
      It sucks because at first tv works always, so I have to wait for a couple of minutes to know whether the changes worked or not haha, but then it fails.
      Another thing, my friend told me that the night that the tv began to fail, tv turned on by itself two times in the middle of the night until he plugged it out. Just if this info is valuable.
      So, any ideas of what more to change? XD
      Edit: From the dtv source I don't get any image, just the menus, but from scart source I get image but with the colors pumping until tv turns off.
      the tv turning on, on its own, while in standby, could mean it was taking an update, and being unplugged has corrupted the firmware update ?
      • Leplus
        • Apr 2017
        • 47
        • Spain
        #43
        Little problem.
        While removing the last cap one of the pads got away.
        Where should I scrape to solder the new cap? Is it ok to scrape right where I have the screwdriver? I don't understand how it should work sorry, Im new at this.
        • Leplus
          • Apr 2017
          • 47
          • Spain
          #44
          But this tv does not have wifi or anything. It was only connected to antenna and power, or am I wrong?
          • finntricky
            • Jan 2014
            • 449
            #45
            Little problem.
            yes that should be ok
            • finntricky
              • Jan 2014
              • 449
              #46
              it can update though the antenna on DTV signals
              • Leplus
                • Apr 2017
                • 47
                • Spain
                #47
                I didn't know, well then I'll google that up and try to check or update the firmware, or reset it through the service menu maybe?
                But I don't know because after several rebooting the tv works. Now tv takes too long to work though.
                I'll arrange the shit I did first desoldering xD
                • Leplus
                  • Apr 2017
                  • 47
                  • Spain
                  #48
                  Quick update.
                  I replaced the last 1000uF 10V cap but the problem remains. I don't know what more to do than take it to a technician
                  • ducky29
                    • Dec 2015
                    • 370
                    • Europe
                    #49
                    Since you have changed a lot of caps, try changing the cap on the sub board, c6108 or something like that
                    • Leplus
                      • Apr 2017
                      • 47
                      • Spain
                      #50
                      That one has been already changed a month ago following this post in russian because I had those exact symptoms.
                      But now a month later this happened but I didn't find anything similar, and I tried disconnecting the sub board and the tv still reboots, as well as disconnecting the inverter or the T-con.
                      So I don't know what else to touch xD
                      • Leplus
                        • Apr 2017
                        • 47
                        • Spain
                        #51
                        And also I have been hairdrying the boards but nothing, now I don't get the tv out of rebooting.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          #52
                          Heating must be doing something if it is making it worse. You will probably need to freeze areas to see if it improves.
                          • Leplus
                            • Apr 2017
                            • 47
                            • Spain
                            #53
                            I'll try it tomorrow with the hairdryer in cool mode but I don't understand it. Yesterday I'd been watching the champions league match after waiting some minutes to have the tv working perfectly, today I can't get it that way even waiting for hours I would say, holy crap.
                            • Leplus
                              • Apr 2017
                              • 47
                              • Spain
                              #54
                              Well, now being cool, tv after 30 seconds reboots, and even being warmed up still reboots, so I don't get any difference heating or cooling with the hairdryer. I'll leave it rebooting to see if it begins to work.
                              • Leplus
                                • Apr 2017
                                • 47
                                • Spain
                                #55
                                Well, after being with the tv on, it continuesly reboots
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #56
                                  What voltage are you getting on your ps-on while rebooting?
                                  • Leplus
                                    • Apr 2017
                                    • 47
                                    • Spain
                                    #57
                                    Mmmmm, you mean at the entrance? AC volts? Or any other point?
                                    At the entrance I'm getting 234acV steady all the time. I can measure whatever you need haha, or connectors or the inverter (but I don't know where to measure exactly there so I didn't try there), I just run out of ideas.
                                    I found another thread about this similar problem but they don't say the solution, just check the LVDS cable or the inverter, but without them disconnected the tv is still rebooting, so I didn't check them and I focused on the ps and the main board.
                                    I also asked in a couple of youtube videos with the same issue but I don't expect them to reply, I'll wait anyway.
                                    • dskall
                                      • Oct 2016
                                      • 2905
                                      • usa
                                      #58
                                      Need these
                                      voltages from connector that goes from power supply board to main board. Will need pin#- PIN DESCRIPTION -Pin voltage in standby-Pin voltage when pushing power button and picture of connector on power supply board.
                                      Format:
                                      Pin# - Pin Description - Pin Voltage standby - Pin voltage power on
                                      1 - XXXXXXX - XXv - XXXv
                                      2 - XXXXXXX - XXXv - XXXv
                                      3 - XXXXXXX - XXXv - XXXv
                                      4 - etc.
                                      • Leplus
                                        • Apr 2017
                                        • 47
                                        • Spain
                                        #59
                                        Need these
                                        Format:
                                        4 - etc.
                                        Ok, I already measured that connector and the other one of 5 pins coming back from main board to ps and all were ok, maybe I'm missing something, so, give some minutes and I'll check again to post it.
                                        • Leplus
                                          • Apr 2017
                                          • 47
                                          • Spain
                                          #60
                                          There you go, connector from ps to main board.
                                          01 - ON/OFF - 0V - 3.41V
                                          02 - N/C (No conexion) - 0V - 0V
                                          03 - Standby - 5,21V - 5.22V
                                          04 - S-GND - 0V - 0V
                                          05 - GND - 0V - 0V
                                          06 - GND - 0V - 0V
                                          07 - 12V - 0V - 11.97V
                                          08 - 12V - 0V - 11.99V
                                          09 - GND - 0V - 0V
                                          10 - GND - 0V - 0V
                                          11 - GND - 0V - 0V
                                          12 - GND - 0V - 0V
                                          13 - 5.3V - 0.65V - 5.36V
                                          14 - 5.3V - 0.65V - 5.36V
                                          15 - 5.3V - 0.65V - 5.36V
                                          16 - 5.3V - 0.65V - 5.36V
                                          17 - GND - 0V - 0V
                                          18 - GND - 0V - 0V
                                          19 - 13V - 0.71V - 12.10V
                                          20 - GND - 0V - 0V
                                          21 - 13V - 0.71V - 12.10V
                                          22 - 13V - 0.71V - 12.10V
                                          23 - N/C - 0V - 0V
                                          24 - N/C - 0V - 0V
                                            09-07-2024, 05:50 AM
                                          • Mirenia
                                            Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                            by Mirenia
                                            got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                            The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                            If this happened once, then the laptop only runs for a few minutes until restart.
                                            This happens regardless while staying in windows or uefi or in a linux environment.
                                            At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                            01-05-2025, 05:15 PM
                                          • vincentedel
                                            Samsung SyncMaster 740n Phase Control Issue
                                            by vincentedel
                                            I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                            I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                            04-22-2025, 12:33 AM
                                          • Manucsl
                                            QE65Q800TATXXC Samsung TV Issue
                                            by Manucsl
                                            Hello.
                                            My TV is a QE65Q800TATXXC Samsung TV.
                                            Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                            Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                            Any ideas to check would be very appreciated 😊
                                            After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                            02-19-2025, 07:47 AM
                                          • FourRunner
                                            Display issue Samsung TV UA65JS9000W
                                            by FourRunner
                                            I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                                            10-03-2024, 07:05 PM
