Samsung LN46B64R3F parts?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i found in the curve this Samsung LN46B640R3FXZA with broken screen,i got it apart and took out all boards including the lamp backlights.
    my question do these CCFL lamp back-lights fit to any other 46" led tv? don't if any of these boards are any good,but there are good parts for any other future repairs,see pic attach; thanks
  • Techstar
    Tv Restoration
    • Dec 2012
    • 122
    • United Kingdom.
    Re: Samsung LN46B64R3F parts?
    All parts should be saved out of any scrap tv. I always salvage backlights both CCFL and LED strips. The boards can either be sold on e bay or used as replacement boards on future repairs . I have loads of storage space so am lucky to have the room to store the bits. For me I have almost an addiction to collecting scrap tv parts . I love having lots of boards to practice de soldering the many types of chips and other bits. I save every single backlight from broken screens. I have a nice collection now.
    • attainteddragon
      • Apr 2013
      • 764
      • australia
      they will fit many other ccfl backlight tv's, but not led.
      the only catch when you change out a single ccfl is that some have a tint to them, blue or yellowish. but if you put the slightly off one on the very top or bottom, it normally isnt noticeable.
      i have a couple of boxes full and are annoying to store. i just write the length and diameter add length on a piece of paper and tape it to each set.
      you could of jumped the ps on to see if the ps and inverter was ok before you stripped it.
      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
      • ivtec
        • Dec 2008
        • 1967
        Thanks guys; i also have a whole bunch of boards from different brands,i normally if screens are broken i strip them right on the spot. and leave the panels and such in there,and bring boards home
        • mikey5791
          Help on Samsung Syncmaster T220 dead ccfl lamp
          by mikey5791
          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
          10-18-2020, 03:17 AM
          09-07-2024, 05:50 AM
        • Mark D
          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
          by Mark D
          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
          10-29-2024, 03:15 PM
        • max789
          Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
          by max789
          Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
          I made the following tests:
          1. Disconnected the main board from Power Board = backlight works.
          2. Connected the main board and disconnected the T-Con = backlights does not work.
          So I ordered a main board from Ebay also BN41-02156A but from...
          01-18-2024, 06:56 AM
          09-06-2024, 11:40 PM
