Hello im searching for dvrs 16leas-h and 08leas-h firmwares
dahua dvr firmwares
Re: dahua dvr firmwares
Here ?
http://novosec.hu/termektamogatas/ca...-FIRMWARE.html
http://novosec.hu/termektamogatas/ca...-FIRMWARE.html -
Thanks but this update doesnt work i try in 3dvrsComment
by akwkyHi!
Incidentally, Windows 11 have recently started auto-flashing computer BIOS in our region. Even more suspiciously, Lenovo has released a BIOS update just few days before the PC was trashed. About a week later, the BIOS update image has been oficially marked...04-14-2025, 01:56 PM -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by iMuhtasebthis board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
One weird symptom is it takes too long to power on and show the Apple logo for some reason..
I've taken a look into the MLB and noticed tiny liquid around Q3100.. its... -
by al3m0diUpdate bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
The BIOS version is EFCN58WW.
When I turn on the device, it displays the message:
"The Connected AC adapter has a lower wattage than the recommended AC adapter..."
The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
I've tried
Channel: BIOS Requests ONLY!
07-29-2024, 10:32 AM -
by spmetroilHello,
I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
I have a CH341A programmer and I already attempted the following steps:- Identified the correct chip (W25Q128, 3.3V SPI flash).
- Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
- Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
08-19-2025, 09:23 AM - Loading...
