Pioneer Kuro 151FD problem help please
  • Inop
    • Apr 2017
    I have a Pioneer Pro 151FD Plasma TV. I've owned it for years and really love the thing. My hope is with your help I can keep it running for a few more years.
    Here's the problem. The tv will either not power up or it'll shut down after working for a while. Sometimes it'll work for hours and then power down. If I unplug it overnight it will usually turn on. If it does turn on, eventually it'll turn off. This is always followed by a steady blue blinking led. I've searched and found several threads about 8 or 12 blinks but nothing about my problem. What I see is a single repeating steady blink. So it'll blink 1 time followed by the light turning off. A few seconds later it'll blink again, then off. This repeats. So far I've taken apart my tv and sent in my main and i/o boards for repair to someone on ebay. Unfortunately this hasn't done the trick.
    If anyone has an idea of what this is I'd really appreciate the help.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Pioneer Kuro 151FD problem help please
    Need good clear straight on pictures of back of tv with cover off and each board.
    • Inop
      • Apr 2017
      Well the tv worked for a few hours today but after it turned off there was something new. Now, instead of a steady blue blink, the blue light flashes twice. I'll do a search but does anyone know what two blinks mean?
      dskall-I'll get a pic for you.
      • freakaftr8
        • Oct 2012
        • 3743
        Did you happen to pull the cover off this time and power up the TV? Now that's why you had the blue blink? I believe this model has a trap switch for back cover intrusion
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          You can try the procedure discussed in the AVS link to reset the trap switch.
          http://www.avsforum.com/forum/167-pl...er-plasma.html
          • pixelcap
            Pioneer Kuro Pro 111FD 8 red blink error
            by pixelcap
            Pioneer Kuro Pro 111FD 8 blink red LED.
            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
            10-06-2024, 11:26 PM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
          • ReeceyBurger123
            Pioneer Kuro PDP-428XD 8 Blue Blink Repair Video
            by ReeceyBurger123
            I'm back again bodging things
            Video covers the repair and diagnoses of my own Pioneer Kuro 428XD which went faulty with 8 blue blinks. Do not attempt anything seen in the video at home haha
            https://youtu.be/O0BS5kg3tNo
            02-21-2022, 12:12 PM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • matpod16
            Pioneer VSX-D1011 - turn on problem
            by matpod16
            Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
            09-07-2023, 01:43 PM
