Changhong 50" LED tv, model LED50YC2000UA
    Re: Changhong 50" LED tv, model LED50YC2000UA
    Remove that IC and then do the same reading on those pads to see if the shorts will go away without the IC in place.
    • jackal68
      • Mar 2014
      • 91
      Unfortunately, after removing the ic, the pads on the mainboard continue to be the same, shorted between GRD and Out
      Where else can I check? Where would the 3.3V out usually go to?
        The output pin (center pin which is connected to the big tab internally) has two SMD Ceramic Caps connected to it, remove the cap one at a time to see if the shorts will go away.
        • jackal68
          • Mar 2014
          • 91
          If you mean the two caps directly above the centre pin (one small and one bigger one, not shown in the picture). I took them out, one at a time, but still the same result....shorted between GRD and Out.
          I took out caps C836 and C871 in this picture
            So with those caps removed when you check the resistance between GND and the output pad, do you still get < 1 Ohm reading?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              C836 solder pads look shorted but it could just be the photograph.
              • jackal68
                • Mar 2014
                • 91
                Yes, when both caps were off, it was still shorted between GRD and Out. In the picture, it shows C836 back in place (and my terrible soldering job)
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Does the voltage regulator output also go to C217 and if so I would check that one too.
                  • jackal68
                    • Mar 2014
                    • 91
                    Thanks for that suggestion. From what I can see, it looks like it goes to C217....so I took it off but still the same.....still shorted.
                      HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                      This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                      09-06-2024, 05:27 AM
                      HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                      This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                      This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                      This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    • edugimeno
                      Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                      by edugimeno
                      Hi!!
                      Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                      I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                      At a certain point, moving stuff around, I put all wires back in place and...
                      03-24-2024, 02:31 PM
