Changhong 50" LED tv, model LED50YC2000UA
  • jackal68
    • Mar 2014
    • 91
    Hi
    I picked up this 50" LED tv (Changhong model LED50YC2000UA) that suffered a power surge and it no longer turns on. The red standby light is on when plugged into the wall, but nothing happens when the power is pressed.
    I opened it up and physically, the power supply board looks good, no burnt marks or bulging caps. I tested the voltage reading from the PS and got the 12V going into the MB, but did not get the 24V going into the LED board. I am wondering if this is a sign that the PS is bad or that the 24V will only go on when the MB is working properly and sends a signal for it to turn on.
    I am attaching pictures of the tv, hopefully someone can direct me to the problem.
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Changhong 50" LED tv, model LED50YC2000UA
    The second part is usually the case. The power isnt fully on until it is told to do so. The main board usually is what tells the power supply to turn on. What is the voltage on PS_on pin of the power board? Actually, post all of the voltages that you get so far on that connector.
    • jackal68
      • Mar 2014
      • 91
      On the cable that goes to the mainboard, i only get the 12v (three of them). All the rest are 0v
      On the cable that goes to the led driver board, I only get the 12.3v (one of them). All the rest are 0v.
      so, to answer your question, PS_on is 0v
      • Dgtech
        E. Technician
        • Apr 2009
        • 1462
        • Steeler
        Ok, that PS_on should be 3.5 -- generated by the power supply. Check for a shorted diode or other defective parts.
        • jackal68
          • Mar 2014
          • 91
          Should it be 3.5v on both cables, the one going to MB as well as the cable going to the LED driver (as both cables have a PS_on).
          • Dgtech
            E. Technician
            • Apr 2009
            • 1462
            • Steeler
            I'm currently watching a video on youtube about this set. Here is the link.
            https://www.youtube.com/watch?v=VwLf7ZGugUo
            • Dgtech
              E. Technician
              • Apr 2009
              • 1462
              • Steeler
              Once we get the 3.5 on the one coming from the power supply then we will see if the other one has it. It should be the same 3.5, but i dont know without seeing a schematic.
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                On this video, this guy has similar symptoms and his problem ends up being a 3.3v regulator not regulating on the main board which overheats the processor. It may not be the same thing but its a good video to get you familiar with some of the set.
                • jackal68
                  • Mar 2014
                  • 91
                  Thanks...it was a very helpful video! Im going to troubleshoot the PS and while I'm at it, i might check the voltage on that regulator in the MB.
                  • jackal68
                    • Mar 2014
                    • 91
                    I started with the same diode on the video....just wondering if my readings are within specs in reference to his. When he measured the first diode, he got .39 drop....i get .34.
                    When he measures the BR, he gets .57, .55. .57 and .565 (all around .57).....i get .50, .48, .49 and .48. I'm wondering if these are off or are they just depending on the meter that you are using?
                    As expected, there is no 3.3v on the regulator on the MB.....
                      BTW, PS-ON is NOT generated by the power supply, that PS-ON command signal comes from the main board and it will be present when TV is turned ON.
                      The PS-ON is used for turning on the rest of the switched power supplies.
                      • jackal68
                        • Mar 2014
                        • 91
                        Does that mean I should be looking on the mainboard and not the PS? I'm not sure what I would be checking.
                          Yep, all you can do (without the main board diagram) is to do good visual inspection, look to see if the HDMI IC is daamged or not, see if there is any fuse on the main board, check the input/output/adj pins Voltage of the Regulator, etc.
                          • jackal68
                            • Mar 2014
                            • 91
                            I looked at the mainboard and it looks like the regulator that was talked about in the video is burnt.
                            https://goo.gl/photos/DmYqsYHtk9zS6J347
                            Can someone confirm that it is burnt and it has a tiny hole?
                              Is that the picture of YOUR 3.3V fixed Voltage regulator IC? You can easily verify by checking the Voltages.
                              • jackal68
                                • Mar 2014
                                • 91
                                Yes, I believe it is. In one of my earlier posts, I stated I had 0v (neg on ground and red on the middle pin).
                                  But you do have input Voltage of 5V to the input of the regulator, right?
                                  And the resistance between the GND and the output pin is >500 Ohms?
                                  • jackal68
                                    • Mar 2014
                                    • 91
                                    Yes, the input voltage is at 5v, but there is no resistance between any of the pins...they all seem shorted.
                                      It cannot be all shorted! How can you have 5VDC to the input pin if it is shorted?
                                      What Ohms scale are you using? What is the ACTUAL readout on the meter display?
                                      • jackal68
                                        • Mar 2014
                                        • 91
                                        You're right...wrong scale. When I put in the 200 ohms scale, i get the following:
                                        GRD and In - 53.8 ohm
                                        GRD and Out - 1 ohm
                                        In and Out - 54.4 ohm
                                          HP ZBook 14 G2 Base Model Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 14 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 G2 Base Model boardview and 14 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ZBook 15u G2 Base Model Notebook 15 Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15u G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15u G2 Base Model boardview and 15u G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • edugimeno
                                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                                          by edugimeno
                                          Hi!!
                                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                                          At a certain point, moving stuff around, I put all wires back in place and...
                                          03-24-2024, 02:31 PM
