Sony KDL-55EX720 5/7 Flash Error
  • germanplumber006
    • Jul 2016
    • 11
    • US
    Hi, so this is where I am currently at on my Sony KDL-55EX720.
    My TV was struck by lightning (on a surge protector) but still got hit.
    So this is what I have troubleshooted and where I currently am at.
    TV won't come on, and am getting a 7 blink error code. This is typically indicative of a bad main board (BATV board per sonys service manual). So i ordered a replacement and swapped it out and now I have a 5 blink error code so I am assuming the main board was bad. I put the old one back in at still 7 blinks.
    5 blinks per sony's repair/service manual says T-con is your culprit or a communication error, but it could also be panel/BATV or even power board. I've tested voltages so I don't think the power board is my culprit but their are technically 3 different power boards on this TV. I also don't think my main is bad as the blink code has changed. LVDS cable looks to be fine as well so I don't believe it is a communication issue.
    Does anyone have any insight on how to test this to confirm T-con or panel? I don't want to sink any more money into the TV if the panel is what is causing my problem.
    Thanks.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sony KDL-55EX720 5/7 Flash Error
    Check for voltage at your t-con fuse
    • germanplumber006
      • Jul 2016
      • 11
      • US
      Just tested. Looks like panel took out the t-con. Thanks.
      • freakaftr8
        • Oct 2012
        • 3743
        You could try disconnecting the panel from the t-con
        • Ihandyrepair
          4 red flash led 65X950G boot Sony and android logo but then black
          by Ihandyrepair
          HI guys
          I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
          here is the issue
          I have Sony and android logo. but then 4 led red flash lights front of the tv
          I have 3.3v ref. 12v reg then T con 12v when I press the power on button
          but then I get black screen and 4 red flash light at the front LED
          but I get 3 led flash on the LED driver board.
          I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
          so I tried...
          07-11-2024, 01:45 AM
        • ekozeko333
          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
          by ekozeko333
          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
          🔥 The Problem Started After Suspected ESD/PD Fault
          I experienced a power issue or ESD event through a USB-C charger
          After that, the NX20P5090 power switch was visibly burned and was replaced
          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • protonusr22
          Sony 49XH9505 four flash of death
          by protonusr22
          I own a Sony 49XH9505 123.2cm Smart Android 4k quite new bough brand new in 2021. Just after the warranty has expired it had died on me.
          The symptoms are the following: right after turning on backlight turns on and this loading screen appears, than the display turns off and the red led flashes four times.
          Any idea how to fix it or if it at least fixable? Does this sign related maybe some SoC/DSP and its circuits or just some simple power supply issues somewhere ?
          Many thanks in advance,
          02-07-2024, 08:10 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
