LG 32LD350 Power light goes blue for 10-15 secs then flashes red
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi Guys
    I did a quick forum search and found some posts about this model but not the fault I have
    First of all - this TV has been dropped, not from a great height but a few feet to land on one front corner. It stopped working after that.
    There is no obvious damage to the casing, screen or PCBs or loose connectors that are noticeable
    What happens is that when plugged in the power LED lights up red. Press the Standby button and it goes blue for maybe 10-15 secs then starts flashing Red
    On the PSU there is a connector with the various pins marked (see pic)
    What I get is (While the blue power LED is on):
    All voltage rails (3.5V, 20V, 12V) are present and correct.
    The pin marked Power -On has 3.25V on it
    The pin Marked Error alternated 3.4V -> 0.6V -> 3.4V -> 0.6V several times, slow enough to see on my DMM
    Then once the Power LED starts flashing Red I get:
    Voltage rails only the 3.5V is present
    The pin marked Power -On has 0V on it
    The pin Marked Error 0V
    Pressing the Standby Button starts the whole sequence again
    Any ideas on this one?
    Cheers
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • vinceroger69
    • Mar 2012
    • 6714
    Re: LG 32LD350 Power light goes blue for 10-15 secs then flashes red
    service manual
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Ahhhh ... found an Interconnect Diagram and schematic from another thread here regards this model
      Unfortunately my PSU does not seem to match the one on the Interconnects diagram but it would seem the TV is trying (and failing) to turn on the back lights). Got the schematic from another thread but they seem to have ommited the PSU diagrams!
      Checked the voltage between the grey wire and the two pink wires (which are connected together) that feed the back lights and nothing there. Just spotted an open circuit fuse on the PSU in the area of the backlight output connectors. Will investigate further........
      Rich
      • vinceroger69
        • Mar 2012
        • 6714
        dont measure the back light voltage with your multi meter as its very high as most meters cant go that high i cant remember the exact figure but someone will advise.
        whats the full model number as there are a few manuals the one i linked is for the ua version of your set
          Firing Voltage is about 1500~2000 high frequency AC!
          The question is do you see the backlights even flash on for seconds if you look at the back side of the LCD panel.
          BL-ON DCV is ?????
          • vinceroger69
            • Mar 2012
            • 6714
            BL-ON DCV is ?????
            Thanks budm i new ccfl/eefl invertors output voltage was high but didnt no it was that high certainly enough to damage a meter etc.
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              OK thanks guys. There is no HT as the 16A fuse is blown. Traced it out a bit - input end of fuse goes to +ve on main smoothing caps of SMPS so should be feeding 350VDC approx via the fuse to HV inverter.
              Other end of fuse goes to the 2SK3868 MosFETS - four of them on one heatsink. Think probably connected as two pairs driving high side and low side of output ransformers (just a hunch). Source of two of the MosFETS goes to the -ve end of main smooting caps. No short circuit from MosFET end of blown fuse to -ve of smoothing caps, no shorts around MosFETS so no obvious reason why fuse has blown at the moment. Checked for short across leads going to backlight.... nope.
              Visually checked PSU PCB for cracks, fractures etc - nothing obvious.
              Where do I measure BL-ON DC Bud? there's not a pin marked as that on the output connector from PSU to main board.
              Rich
              • vinceroger69
                • Mar 2012
                • 6714
                i think its inv on off
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  Oh, full model number = 32LD350ZA
                    This is your board, right?
                    LG EAY60869102 (EAX61124201/15)
                    Pictures provided by shopjimmy.
                    • dicky96
                      Sun Seeker
                      • Mar 2017
                      • 1825
                      • Spain
                      INV ON OFF does 3V...... 0,6V.....3V....0.6V....3V.....0.6V/.....0V
                      Think maybe I should just replace the fuse and see what happens. Unfortunately I don't have any suitable ones here in Gran Canaria but am returning to UK for 18 days on Monday so could bring some. Would be nice if I had my variac and mains isolation transformer here to but they are two heavy to carry unless it is really worth my while. Same goes for my trusty analog Techtronix scope.
                      I could replace the fuse with something like a 100W light bulb and fire it up just to see if the inverter oscillates- that's an old trick I use when working on suspect SMPS or big audio amps that are likely to go BANG. Seems the worse that would happen is the bulb lights up - Any thoughts on that?
                      Rich
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        @budm sorry crossing posts in the night here lol. Yes that's the one.
                        Oh sorry no/. It looks like that but it is a 201/14 not 201/15
                          So for sure that there is no low resistance readings between Drain and Source pins all 4power MOSFETs driving transformers, and the blue small disc snubber caps in that section all OK?
                          Fuse that high of current rating to blow the current draw was very very high.
                          • dicky96
                            Sun Seeker
                            • Mar 2017
                            • 1825
                            • Spain
                            FIXED.
                            I really couldn't see any low resistance readings around the Inverter Drive so I (as a temporary measure) got a 13A mains fuse as I didn't have the correct 16A one and soldered a couple of wires to it from the PCB.
                            The backlight then comes on and the TV works fine
                            My humble opinion - as I stated originally this TV had been dropped, it was not connected to mains at the time. It is possible the physical impact caused the wire inside the fuse to break rather than the fuse blowing in the normal elecrtical sense?
                            When I bring some more kit over from the UK in a few weeks I will bring my small bench vice to hold the 'blown' fuse and cut it open with my dremmel. I'll bet once I look inside it has not 'blown' per se.
                            Anyway TV working, awaiting correct fuse on my return
                            Rich
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Are you certain that it's a 16 amp fuse and not a 1.6 amp fuse. Seems awful high value to be in a TV set!!!!
                              • dicky96
                                Sun Seeker
                                • Mar 2017
                                • 1825
                                • Spain
                                It does doesn't it. You can see it on the pic of the psu (component side) that bud uploaded - top right, next to two big inductors - fuse has two stripes on it. Below that you can make out F3 16A though it looks more like 15A on the pic from bud
                                So it's marked on the PCB as 16A but just looked on the actual fuse and it is actually a 3.15A!!! Still don't have one here though so will have to wait until I bring more kit back with me from UK
                                Ahh I see now it is saying on the pcb 'F3 15A' as a rating (without the decimal point) not the component F3 rated 16A lol
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  F3. 15Amp is a 3.15 amp fuse. Poor spacing between digits.
                                    Since the TV was dropped, you should look for hairline crack on that power supply board just in case there is intermittent connection in that Inverter section.
                                    • dicky96
                                      Sun Seeker
                                      • Mar 2017
                                      • 1825
                                      • Spain
                                      @budm
                                      Will do bud - I have already had a look under my bench magnifier but will try flexing the board very slightly under the magnifier and see if there is something I missed
                                      @dick barton. Yes agreed mate, as I said the fuse is rated 3.15A when I examined the fuse itself. The spacing between digits on the screen printing is very bad. What also threw me is the fuse is physically large, not like your normal 3.15A in line fuse. Will look out for anything like that in future
                                      Back to the UK now for a couple weeks, gotta deal with some business as we are trying to sell up there. Can't wait to get back to Gran Canaria and it's sunshine, beaches and At least I can bring more of my electronics kit back with me
                                      Cheers
                                      Rich
                                      • Egidio85
                                        Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                        by Egidio85
                                        Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                        the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                        the fan does not start.
                                        I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                        any advice on what to check?
                                        06-10-2025, 05:00 AM
                                      • cajoeg
                                        Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                        by cajoeg
                                        Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                        The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                        02-10-2025, 04:01 PM
                                        Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                        This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-07-2024, 05:50 AM
                                        Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-07-2024, 05:00 AM
                                        Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
