Dear friends
I own a Philips 42PFP5532D/12 plasma tv which stopped working a few months ago.
When I try to power on the tv set, I hear a clicking sound inside and the front led starts blinking.
So, I opened the case and the first thing I checked is the power supply (the known to many of us, Samsung PS-507-PHN).
At first, I checked for blown fuses and shorted diodes with my DMM, and for shorted coils with the Blue Ring ping tester. All of them looked ok (I unsoldered them prior to testing).
Then, I found many blown output capacitors and replaced ALL of them with the exact same values.
After replacing the bad caps, I tried to turn on the PSU by bridging the D5V and VS_ON pins but after a few seconds, it shut off and the small fault board started blinking twice, which means VA error.
So after that, I found out that the VA voltage starts rising till ~200VDC (it should be 61-65VDC) and then it shuts off.
Then I checked the optocouplers, zener diodes and resistors but everything was ok.
I also replaced the PWM IC and the shunt regulator with new ones.
The problem persists, and the only thing I can guess is a bad smd cap which has to do with the PWM IC oscillator.
Any ideas dear friends?
I have spent many hours looking for the problem because I want to get better on troubleshooting SMPS's.
Thank you in advance for your time and I apologize if I tired you!
