Hitachi L26DG07U
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Hitachi L26DG07U
    Hello all, I have here a tv a friend gave me, It stopped working for him, No power at all, I had a quick look and AC side seems fine but the DC side is unlabled so I'm not sure which wires to test,
    Does anyone know how i would go about fixing this problem,
    I've included a few pics so hope that helps,
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Hitachi L26DG07U
    1. Check fuse first....they are not good?..... NO....replace with same type and rating...does it work now?
    2. Check fuse first....they are good?.....YES.....measure for St-By voltage approx. 5Vdc on cable from PSU to Main Bd.....NO St-By voltage?.....Replace PSU....does it work now?
    3. Check fuse first....they are good?.....YES.....measure for St-By voltage on cable from PSU to Main Bd...YES St-By voltage approx. 5Vdc present...Press power button to turn on set....Ps-ON signal from Main Bd??
    • dskall
      • Oct 2016
      • 2905
      • usa
      Any pin markings on mainboard or on backside of boards?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Power supply circuit board looks very similar but not identical to, however should be a guide.
        • Easky15
          • Sep 2013
          • 285
          • Ireland
          Ok, got new Power board and now the set powers up but there is a slight high pitched squeal fro the board and it goes back to standby about 5 seconds after powering on,
          Would i be right in thinking that is possibly bad caps?
          • dskall
            • Oct 2016
            • 2905
            • usa
            Sounds like a short on the secondary side
            • bouny56
              Lenovo E15 Nm-c421 usb-c work only in one side
              by bouny56
              ​Hello
              Laptop E15 I5 10gen
              Mb nm-c421
              I have a problem with the usb-c power dc.
              The motherboard start only in one side of the usb-c
              Replace the usb-c port 2 times same problem
              With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
              Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
              Can the pd controler be the fault ? Or something else maybe ?
              Thx
              02-11-2025, 03:15 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • flibidy
              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
              by flibidy
              I have here a Magnum IA.100 which belongs to my parents.
              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
              What Ive done........
              01-01-2025, 01:26 PM
            • Stephen
              A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
              by Stephen
              Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
              05-29-2025, 10:35 AM
            • dicky96
              Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
              by dicky96
              Hi guys
              I have a faulty Xilence ATX PSU here
              The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
              There is another smaller transistor on the primary side C3866 which tests ok
              The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
              There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
              05-11-2021, 07:55 AM
