Horizontal Lines On Warmup
+ More Options
Posts
  • Krankshaft
    • Jan 2007
    • 2328
    I have a Toshiba 27" CRT purchased in 03 that has recently been doing something odd.
    On powerup horizontal white lines are in the picture near the top of the screen. As the set warms up these lines drift away towards the top of the screen until they are no longer visible.
    As long as the set is warm the lines aren't there so if I quickly power down then up I'm fine.
    I'm thinking a capacitor issue here but where should I check?
    The vertical deflection or the video section?
    I always thought that capacitor related vertical deflection problems manifested themself as improper vertical deflection.
    I have an ESR meter so I'll find the little bugger even if it's not bulging.
    I gave the TV a few whacks and it didn't affect the picture so it's probably not a loose solder joint it could be a cold one though.
    Thanks for the help in advance.
  • Wizard
    • Mar 2008
    • 2296
    Re: Horizontal Lines On Warmup
    100uF drying out in the vertical circuit. Easy fix.
    This is what causing the vertical foldover because the vertical boost flyback capacitor is not pushing out 48-50V kick to kick yoke back up from bottom to upper due to dried up capacitor feeding by vertical 24V-28V (direct to the vertical) via a diode to cap's + side while - side goes to the vertical IC internal transistor switch that temporily hook cap plus this supply for boost flyback.
    It will KILL the vertical IC if left in that condition long enough.
    Cheers, Wizard
    • Krankshaft
      • Jan 2007
      • 2328
      Thanks alot!
      I checked the 100uf 35V Rubycon 85C in the vertical circuit and it's ESR was 33 ohms. This board was impressive all top tier caps (Rubycon, Nichicon, Chemicon) I guess it's 85 C temp rating was the reason for it's demise.
      It seems like Toshiba had the ingenius idea to put both the Vertical output IC and HOT on the SAME heatsink.
      This cap was merely 1/2" away from this heatsink so it probably was baked.
      I replaced it with a GP KMG Chemicon at 105C (all I had in 100 uf at 35 volts) so hopefully it will survive since it's a higher temp rated cap.
      Replaced it and I'm back in business .
      • Wizard
        • Mar 2008
        • 2296
        That's not toshiba chassis, toshiba never put vertical and horizontal stuff on one heatsink. White label for model # on back, citizen chassis.
        True toshiba chassis is yellow label.
        Cheers, Wizard
        • Krankshaft
          • Jan 2007
          • 2328
          I never knew that I guess my Toshiba branded RPTV with the white label on the back is Citizen as well.
          Already went through a set of convergence amps on that one .
          • Wizard
            • Mar 2008
            • 2296
            Not always
            I know Citizen doesn't make RPTV.
            If youi have pics of chassis, I might able to ID.
            Cheers, Wizard
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • noisykid
              Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
              by noisykid
              5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
              12-30-2024, 07:15 PM
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • oxi1158
              Toshiba TV 55L6200U horizontal lines + vertical bands. Any hope?
              by oxi1158
              My TV had been showing for the last year some faint horizontal lines on all of its right side, about one out of each 4 of 5 rows of pixels. Not much of a bother, they were unnoticeable when watching a movie. Then, all of a sudden the horizontal lines became much stronger and crossed the whole screen, effectively making it a pain to watch.
              I watched some youtube video where some guy "fixes" it with some tape on the ribbon cable of the t-con, so I tried that, but to no avail. Actually, after putting the TV back together again things worsened: apart...
              10-09-2020, 08:37 PM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
