Study RCA LED55C55R120Q TV
  • capwizard
    • Jun 2016
    • 1991
    I have two working RCA 55" LED TVs.
    A is a LED55C55R120Q
    Serial No. 3527-LE55C55-B100491
    Jan 2014 Made in China
    Panel No. LSC550HJ03-12v...........It is a Samsung panel
    RCA 55120RE01M3393LNA5-B1 Main Board SoC is MSD3393LUM
    B is a LED55C55R120Q
    Serial No. 2505-LE55C55-A105154
    March 2013 Made in China
    Panel No. T550HVN02.1-QYE............It is a AUO panel
    RCA 55120RE010C878LNA0-A1 Main Board SoC is R8A66983BG
    More is over here
  • mon2
    A2141 Not powering on - case study
    by mon2
    This is a case study on a 'sudden death' A2141 unit brought in for service.
    USB-C meter is @ 5v with ~0A current draw.
    a) Disconnected battery. No power to the machine. Applied the Qianli Tail tester with the USB-C connector. Each USB-C power connector was green with the diode mode of testing. CD321x are not defective as originally thought.
    b) PPBUS_g3h is not shorted but is a low voltage due to the low INPUT voltage of 5v being boosted. On a random power up attempt, PPBUS_g3h was at the expected 12v63 range AND input voltage was observed to be @ 20v for...
    07-10-2025, 10:58 AM
  • mon2
    NM-B501 BIOS / Battery ONLY case study
    by mon2
    See attached.
    06-24-2024, 06:08 AM
  • alex92ayfer
    Case of study - Lenovo Legion Y530-15ICH
    by alex92ayfer
    Hi all!
    I am self-taught in motherboard repair and I find myself somewhat lost.
    Motherboard name: NM-B701
    The info that i have:
    The board arrived with a short on the 3VALW line (0.2ohms). I take out the coil and the short is on both sides. I remove the 3VALW AND 5VALW controller (RT6585) and now I only have short on the load side. I inject voltage (2v) into the 3VALW line and with the thermal camera the PCH heats up in one corner. I take it out and now 3VALW is at 270ohms. I inject 3v again and now the EC heats up. I remove it and short is gone (line...
    10-18-2023, 01:19 AM
  • iacopo
    Case study: apple A1311 firmware locked
    by iacopo
    A client brought in a IMAC A1311 that had been firmware locked and said he forgot the password.
    I fixed the problem by reading the ROM and removing the part where it enabled the firmware lock and rewriting it to the MAC.
    In my case this is what i did: i search for the string of text "$SVS" inside the dump, and found there were two, the first one was followed by a lot of non 0xFF bytes, the second one instead was followed by only a few non 0xFF bytes.
    What i did to fix it was copy the second apperance of "$SVS" along with all the...
    07-25-2023, 04:56 AM
  • capwizard
    Study R8A66983BG
    by capwizard
    System on a chip SoC : R8A66983BG
    A system on a chip or system on chip (SoC or SOC) is an integrated circuit (commonly called a "chip") that integrates all components of a computer or other electronic system. It may contain digital, analog, mixed-signal, and often radio-frequency functions—all on a single substrate. SoCs are very common in the mobile computing market because of their low power-consumption. A typical application is in the area of embedded systems.
    The contrast with a microcontroller, SoC integrates microcontroller (or...
    03-09-2017, 01:12 PM
