Toshiba 32BV500B fault - Vestel 17PW26-4
  • orbiter
    • Mar 2011
    • 37
    Hi guys just got a Toshiba 32BV500B to repair. It has a Vestel 17PW26-4 PSU.. The initial fault was that it wouldn't turn on at all, no standby LED or anything..
    So I did some tests firstly checking the PCB fuse which was blown, then I checked every capacitor (out of circuit) and found all except C874 to be within spec and have good ESR.. I replaced both the fuse (with temporary 3A one) along with C874. However there was still nothing on power up.
    So.. Did some more tests and found D893 failed along with transistors Q813 & Q814.. So I went ahead and replaced those too.. On plugging-in the tv it then fired up and the screen came on for about 30 seconds.. Then both the replaced transistors exploded again with the source leg being blown off both.. At the same time the pcb fuse and D893 had failed again
    So I guess I've got a short here when something switches after about 30 seconds after power-on.. I've not yet replaced IC830 (FAN7711)
    Here is the PCB and replaced components in red...
    Anyone got any advice please?
    Don't Bin It - Repair It.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Toshiba 32BV500B fault - Vestel 17PW26-4
    this is whats in the repair kit for this fault so best replace all parts
    F800
    Q813
    Q814
    IC830
    D894
    R860
    R8661
    R971
    C840
    • orbiter
      • Mar 2011
      • 37
      Wow.. Great response speed there Vince, thanks very much indeed. I've got all those bits so I'll get on it.
      Thanks again
      • diif
        • Feb 2014
        • 6978
        • England
        Maybe D882 and D883 also.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          There are repair kits online but usually better to source the parts yourself as cheaper its a pity they dont give the values of the resistors etc but should be on the schematic or printed on the smd parts.
          Edit as diff says maybe best to change D882 and D883 as well as we have saw these failed in other threads on here
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            D893 feed capacitors C931, C961 & C962 and which are across the 24V supply. I would check that you do not have a short circuit across the 24V supply. You can measure across any of the above capacitors.
            If you do have a short circuit or low ohms that would account for the mosfets blowing as well. If D881 fitted then check that diode too.
            Also as suggested above check D891, D892, R860, R861, R864 and R865. If any of those are damaged then change the FAN IC
            • orbiter
              • Mar 2011
              • 37
              @diif.. Ok I'll check those. Thank you.
              @vince.. Ok thank you, I think I have all the parts in my stock, and also an app for when I get stuck with my resistor values
              @dick barton... Ok I'll check those too.. Thank you.
              Thanks all
              • diif
                • Feb 2014
                • 6978
                • England
                I have a 17PW26-4 here, I don't know if it works or not but I can measure any values you might need if it helps.
                • orbiter
                  • Mar 2011
                  • 37
                  I appreciate that diif thanks.. I'll get back to you if necessary.. Up to now though I've found that the two 33ohm smd resistors R860 & 861 are reading way off.. in the Mohm range actually so I'll swap those after my tea and check the rest of the stuff too. I'll let ya know how I get on.
                  Thanks again.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    I would change the FAN7711 as a precaution.
                    • orbiter
                      • Mar 2011
                      • 37
                      Hi again fellas...
                      Just an update... So I've got the power supply going to a certain extent BUT the LED on the front of the tv is flashing constantly I've tried holding the touch sense power button for 20 secs etc and leaving the tv alone for a while in the hope that it would reset, but the LED still just flashes away.. No fault CODE flashing.. Just continuous flashing.
                      I've started checking voltages at PL816 which is the socket off to the main pcb (schematic below) and a couple of voltages are missing there.. I do have the following though.
                      +3.3v standby (pin 16)
                      +5v standby (pin 14)
                      But no +12v or 24v (pin 12)
                      The only real thing I can't check fully is the Fairchild IC (FS DL321.) which is a PWM controller, this has 20v on it's ground pin :o .. Now I'm hoping that this is an internal short.. So I've ordered a couple of those from eBay and they should be here today or Monday
                      BTW.. The main board is a (17MB45M-3)
                      17PW26-4 Schematic... https://www.mediafire.com/?c1rn8stprfp791x
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Disconnect the main board and on the power supply connect a 1K resistor from +5V standby to Stby (pin 6) and then check 12/24V
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          This pdf has some good information regarding the psu etc
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Interesting. Thanks
                            • orbiter
                              • Mar 2011
                              • 37
                              Hi guys,
                              Sorry for not responding sooner, for some reason I did't get notification that there were any replies
                              even though I am subbed to the thread and instant notifications are set to ON.
                              Anyway.. I've reaplced DL321 and there's no change anywhere.
                              @dickbarton.. I've just tried whast you suggested but there still no 12/24v
                              @vince.. Thanks for that .pdf it's very helpful.
                              pin 4 =8v
                              pin 6 =2.5
                              pin 13 =0.14v
                              pin 14 =5v
                              pin 15 = 3.3v
                              pin 16 =3.3
                              pin 15/17/19/21 =0.2v
                              pin 18/20/22 =0.4v
                              pin 25 = 0.14v
                              pin 26/28 =0.14v
                              Is there a way that these PSU's can be powered without the mainboard connected guys?
                              Thank you
                              • orbiter
                                • Mar 2011
                                • 37
                                As it's not possible to edit posts here guys?.. I just needed to say that the voltages in my previous post are with the tv turned on (with stby light continually flashing)
                                I could do with some more advice please guys if you have some..
                                Is the PSU supposed to show the correct voltage at its output without having the mainboard connected guys?
                                Thank you
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  What was the original part number for D893 and what have you put in its place. Was the original an UF5404?
                                  There's also a reference in another post relating to these power supplies to a 0 ohm smd link on the underside of the board that can go open circuit so you lose your 12/24V supply.
                                  https://www.badcaps.net/forum/showth...light=17PW26-4
                                  • orbiter
                                    • Mar 2011
                                    • 37
                                    Ahh... Perhaps wrong diode.. The original diode was a UF5402... I fitted a 1N5408 (1000v)
                                    • orbiter
                                      • Mar 2011
                                      • 37
                                      Looking at the diodes specs though a 1N5408 should be fine?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        uf 5402 is a ultra fast diode im not sure about the in 5408 i think thats just a general purpose one?
                                        • lberkani
                                          Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
                                          by lberkani
                                          I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
                                          The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
                                          The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
                                          I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
                                          - Toshiba 65UL2163DG
                                          - Vestel 17MB180E mainboard
                                          - Panel VES650QNTX-N2-N42
                                          - Version V1.28.100.0 if available
                                          If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
                                          11-11-2025, 12:37 PM
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
