How does a panel fail this bad?
  • sugar_ray
    • Dec 2012
    • 121
    It's been our everyday tv for the past 7 years. It's a Toshiba Regza
    It's taken about a year to get to this state. No question a bad panel so I'll have a nice donar. Believe it or not, it started as pin hole spot and has grown slowly and seems to be spreading like a cars windshield crack.
    Just a matter of how much longer I can stand it before buying a new set 😆
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4464
    • Italy - Milan
    Re: How does a panel fail this bad?
    I think it has take a blow, the crystal's liquid is now spreading..
    • tw2005
      • Oct 2011
      • 6458
      looks like a cracked panel
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ive had similar, unsure if the foils in the panel part due to age then cause black spots unsure.
        • petehall347
          • Jan 2015
          • 4439
          • United Kingdom
          its bleeding from a crack by the looks of it
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            The TV does not turn on, the standby indicator is on. All voltages are present.
            Emms is dead. Not readable, not detected.
            Replaced emmc.
            But with another dump there is no launch
            Terminal log
            UART
            AC_ON
            RPMB key is not yet programmed
            HASH1_VERSION=0x00000000 64bit
            E-B
            FDE enabled
            layout pattern onebin by SAR7,0...
            06-01-2025, 02:11 AM
          • howardc64
            LG 49UJ6500 LCD panel lighter band that goes away
            by howardc64
            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
            02-19-2023, 12:13 AM
          • triplefour
            SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
            by triplefour
            TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
            tcon is built into mainboard.
            Only one cable goes to panel boards.
            there is a cable from one panel board to the other that links them.
            cost cutting measure that results in us having harder time to diagnose.
            removing the link to the second panel board allows TV to stay on with stable backlight but no image.
            used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
            07-28-2022, 07:59 PM
          • Storyteller12
            QN55Q60R Service Menu Panel Help
            by Storyteller12
            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
            01-13-2024, 01:57 PM
          • maneatingmonkey
            Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
            by maneatingmonkey
            I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
            There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
            03-27-2024, 07:17 AM
