Panasonic TH50U30A
  • chrismurphy
    • May 2014
    • 251
    • australia
    Panasonic TH50U30A
    has anyone a circuit diag for the power supply ,both boards small and large
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Panasonic TH50U30A
    delete error
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • VitalComputing
      Taking Pictures Of Large Circuit Boards
      by VitalComputing
      Hi friends,
      I am trying to take good quality pictures of rather large desktop motherboards for a project I'm working on. I had a brilliant idea of scanning them with a flatbed scanner I have but it only focuses on the bits of the board that are flush to the scanning glass. And the through hole components tend to lift the main board from the scanning glass. Everything else just looks out of focus. So it seems that that option wont run.
      I have been capturing the images with my iPhone 11 and it's okay but wont capture the whole board. I have to grab it in sections and...
      11-22-2022, 04:15 PM
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • valvashon
      Repair Success! Middle Atlantic UPS2200R-IP
      by valvashon
      Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
      Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
      02-06-2024, 12:54 PM
