KDL-46BX450 Backlight?
  • fcisolutions
    • Jan 2017
    • 205
    Here are my pictures and voltage readings. I get a brief "SONY" logo and then pic goes black. It doesn't seem to pass the flashlight test but I'm wondering about that as I'm using my phone and the light might not be bright enough.
    I'm thinking I have a bad backlight as there is voltage on BL-ERR but not sure how much voltage is needed to trigger the protection circuit.
    cn6401
    1. 3.3 Tcon-on
    2. 12.4 T-con vcc12v
    3. n/a NC
    4. 1.7 Dimmer
    5. 3.1 BL-ON
    6. 1.7 BL-ERR
    7. 12.4 REG12v
    8. 12.4 REG12v
    9. 0 REG12vGND
    10. 0 REG12vGND
    11. 0 AudioGND
    12. 12.4 Audio12v
    13. 3.3 Power On
    14. 3.1 AC Off DET
    15. 3.3 STBY3.3
    cn6402
    1. 25.19 UNREG24V
    2. 25.19 UNREG24V
    3. 25.19 UNREG24V
    4. 25.19 UNREG24V
    5. 25.19 UNREG24V
    6. 0 GND
    7. 0 GND
    8. 0 GND
    9. 0 GND
    10. 0 GND
    11. 1.7 BL-ERR
    12. 3.1 BL-ON
    13. n/a NC
    14. 1.7 Dimmer
  • fcisolutions
    • Jan 2017
    • 205
    Re: KDL-46BX450 Backlight?
    Transformer resistance on the inverter:
    T100 1274
    1274
    T200 1270
    1268
    T300 1176
    1333
    I'm assuming transistor T300 is bad.
    • R_J
      • 9555
      Yes the transformer could be bad, I did'nt see pictures of the inverter so I was going to suggest checking it also.
      • fcisolutions
        • Jan 2017
        • 205
        Can't seem to find these. I did find a "NEW REPLACEMENT" which has wires soldered to contacts that go to the CCFLs. What do you think of this:
        http://www.ebay.com/itm/New-replacem...cAAOSwdGFYpmji
        • fcisolutions
          • Jan 2017
          • 205
          So should this with the power supply in the on condition pass a backlight test?
            Acer Extensa 2519 Notebook 15 Specification for Upgrade or Repair
            This specification for the Acer Extensa 2519 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 2519 boardview and 2519 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer Extensa 2519...
            09-06-2024, 08:50 AM
          • digitalblade
            Acer Extensa 2519 - n15w4 Battery problem
            by digitalblade
            I've an n15w4 with a very strange problem.
            I received the laptop after a failed bios update, so I downloaded the bios from Acer website, then after extracted the bios from installation package (with correct size, I extracted it from bios.bin file)
            I reprogrammed the eeprom (after make a backup anyway), now the laptop start (the bios have a fake serial number and fake device name.. something like 123456789012 and acer_xxxx but it's work)
            Everything went ok, but now I still have a problem... seem that the battery won't charge (seem, but I...
            02-25-2022, 11:23 AM
          • jimbo-bob
            Sony bravia kdl 46nx700 dim screen issue
            by jimbo-bob
            I have a Sony bravia kdl 46nx700. It turns on, but the screen is awfully dim.
            Things I have tried:
            Went into settings and increased the brightness and contrast. Screen did not change at all.
            Went into settings and made sure any auto brightness settings and limit is turned off. Did not see any difference again even after playing with brightness and contrast.
            Did a factory reset. Again no change. Then repeated the steps above. No change.
            At this point I think with myself that this is a hardware problem. Since my tv does not have any...
            02-04-2021, 04:33 AM
          • heathloder
            Sony XBR-65X850E - has standby 3.3V, but won't power on - no status lights
            by heathloder
            I have a Sony XBR-65X850E that won't power on, and has no status lights.
            Immediately upon plugging in the TV, it tries to power up (before pressing anything). I can tell because after plugging the TV in, the main transformer on the power board begins buzzing, 2 seconds on, 2 seconds off, and it does this exactly 7 times before the TV goes back to an “OFF” state. If I press the power button on the TV, the same cycle repeats. I can confirm that no ‘status' LED's are lighting up when this happens. The backlights also do not turn on, but I can confirm that they at least “light...
            04-04-2020, 07:36 PM
          • brad2157
            Sony KD-65X750F - no lights/picture/sound
            by brad2157
            I searched the forum first, but could not locate anything with this model Sony TV.
            Sony KD-65X750F
            There's good AC power going into power supply board. There is no standby light lit on the TV / no picture / no sound using either remote control OR power button on TV. I'm new at troubleshooting TV's, so here are the measurements I took. I am leaning toward thinking it's a main board issue, but wanted to see what others with experience thought. Anything I can go further test to help isolate the issue?
            CN6401 Connector Pin measurements:
            11-18-2021, 08:46 PM
