Vizio E500i-A0 Slight flicker
  • Hamm
    • Jan 2017
    • 20
    Purchased a Vizio E500i-A0, and was excited to bring it home and get it set up. Upon doing so, I noticed a slight flicker on the screen. Seems to be a backlight issue of some sort but I can't figure it out exactly. If I divided the screen into 5ths (horizontally, with 5/5 being the very top) this is in the 3/5 area, if that makes sense. It's also slightly darker in that area (when it isn't flickering). Currently I have the back case off the tv. Didn't notice any bad caps, so I figured someone here may be able to help. I tried to get a picture, but I couldn't get a good one.
    Any and all help is appreciated!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio E500i-A0 Slight flicker
    Bad led
    • Hamm
      • Jan 2017
      • 20
      And the LED strips are replaceable, correct?
      • dskall
        • Oct 2016
        • 2905
        • usa
        Yes, but involves taking panel apart which runs risk of breaking panel.
        • dskall
          • Oct 2016
          • 2905
          • usa
          You might want to just use it until it quits before you try a repair to backlights. Also run backlights down as much as possible to take load off LED's. Update your firmware.
          • fixit007
            Samsung flicker - BN44-00932T board or else?
            by fixit007
            I picked up this TV that the prior owner said - just died.
            Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
            Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
            Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
            05-04-2024, 06:14 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
