Grundig XEPHIA 42 PW no image
  • LE GRAND
    • Jul 2014
    • 34
    • TUNISIA
    Grundig XEPHIA 42 PW 110-6605 chassis P7
    PSU TNPA3570
    Sub power R84-194R-5
    YSUS Board TNPA3543
    SS Board TNPA3544
    Main R82.190R-3
    Old plasma tv no image
    Standby led is turning to blue from red if i press a ke(menu) from front panel but no image
    IN PSU TNPA3570 There is 0volts in main cap C466 so no Vsus in connector P2
    The only voltage in all connecters is 14V in PIN 4 connecter P12
    Main cap 0v
    D404 coming 220v out 194V may be strange
    D403 no incoming voltage
    IC501 1 pin 4.5V
    So any idea
  • LE GRAND
    • Jul 2014
    • 34
    • TUNISIA
    Re: Grundig XEPHIA 42 PW no image
    Help please
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Disconnect P2 and P11 on the PSU. Try a power up, measure Vsus and Vda. If these voltages are produced and stable then your PSU is good and your problem could be in the Y-SUS and/or X-SUS Bds. Are you hearing the relays click when trying to power up?
      • LE GRAND
        • Jul 2014
        • 34
        • TUNISIA
        After Disconnecting p2 and P11 theres is no Vda no Vsus
        im hearing relay click but in board Sub power R84-194R-5
        • LE GRAND
          • Jul 2014
          • 34
          • TUNISIA
          So any ideas or links
          • tuner2000i
            Philips 65PUS8518/12 distorted image after main board replacement
            by tuner2000i
            hello everyone,
            I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
            The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
            07-15-2025, 01:15 PM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
          • salah11
            No Ringer Sound in Intercom outdoor panel (Voice Communication Works)
            by salah11
            I have a persistent issue with a commercial intercom system (likely made in Turkey, based on the unit). Voice communication (audio) works perfectly, but the outdoor panel did not return the ring when the call button is pressed.
            Whell the system consists of three main circuit boards (see attached photos):
            A. Board 1: Power Supply / Ringer Generator (White Board) with LS1240A, BD442 and BD140 Power transistors for ring amplification.
            B. Board 2: Handset (Indoor Unit) Role: Contains the microphone, the speaker/baffle, the manual hook switch, and the open-door...
            11-21-2025, 01:08 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
