Fixing a Philips 50PFP5332D/37. The power board had a blink code 8 for thermal. Checked the thermal resistor and it checks out fine lowering the ohms when being heated. I can't find anything on this TV as far as repair manuals so I am at a loss. There is no standby voltage. Any suggestions would help.
Philips 50PFP5332D/37 8 blink code (thermal)
Tags: None
Re: Philips 50PFP5332D/37 8 blink code (thermal)
Caps around thermal show as good. Transistor doesn't show as stuck open but I can't open gate unless put 9 volts or more on it. Even then only stays open for a second. Bridge rectifier shows that it is working only on last pin reads double the ohms as the rest. -
Could we get pictures of the back of the TV with the rear cover removed so we could see how the various boards are connected?Comment
With all the boards connected measure the Std-by 5V. Once you have that. Unplug the connectors with Vs supply on the PSU from the Y-SUS and X-SUS Bds. Measure the Vs voltage. It should be 200-215Vdc if produced.Comment
OK I will check it again when I get home. Last time I checked I wasn't getting any power to anything. All pins showed 0v. But that's while boards were disconnected.Comment
Stand by shows as 7 volts. There is no measurements from vs pins.Comment
The thermister sits at 70 ohms at room temp but lowered when Heated.Comment
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
ALL LCD LED TV SERVICE MENU CODES
Service Menu Code with Board Name
China Universal Board / Jumper Board Service Menu Code
Changhong Ruba Service Menu Code
Ecostar LED TV Service Menu Code
Orient LED TV Service Menu Code
Haier LED TV Service Menu Code
TCL LED TV Service Menu Code
Samsung LED TV Service Menu Code
LG LED TV Service Menu Code
Videocon LED TV Service Menu Code
Supra LED TV Service Menu Code
Toshiba LED TV Service Menu Code
Symphony LED TV Service Menu Code
Veste/ LED TV Service Menu Code...-
Channel: Schematics and Boardviews
10-31-2024, 03:58 AM -
by eurgencaHello.
I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
So I ordered a used CPU board, and now I have wired picture.
I think the problem lies in display option code. According to SM, the command for setting
display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
or can I manually edit option code in SAM. -
by rmacintoshI aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
The symptoms of the tv ar as follows:- Plug AC in to back of TV
- After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
- The 3 blink code is given by the power LED
- If the TV is unplugged and then
by djordjeHello all,
I have Philips Oled 55 (804/12) with black screen and red light blink.
I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
When i power only psb and tcon with 4 ribbons for panel i only get black screen.
My questions is what should i do next... - Loading...
