need help with mosfet cross reference
  • Larry420r
    • Feb 2017
    • 27
    I have two dead mosfets reading
    RJP30H1
    46T
    1C35
    what can I safely swap them with?
  • Larry420r
    • Feb 2017
    • 27
    Re: need help with mosfet cross reference
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      There are a ton of them on ebay. The cheaper ones are surface mount, I would trust them to be REAL. I have soldered them to a brite shinny penny, for the heatsink, and some stiff wire soldered to the legs to go through the holes. Its called "cheap mother f er" fix.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        USA Ebay supplier
        https://tinyurl.com/h5kkfax
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          https://www.utsource.net/search.aspx...RJP30H1&page=1
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • Nooy
            VGA MOSfet permanently shorted and loss of MOSfet pad
            by Nooy
            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
            02-14-2024, 02:26 AM
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
          • connorcc2005
            Thermistor specs and cross reference
            by connorcc2005
            I'm getting some conflicting information and thought I'd toss it out to all of you for input.
            What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
            The physical diameter of the piece is 5.1mm measured with a caliper.
            Other than what you see in the pic, there is no other writing on the part.
            My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
            06-16-2022, 04:16 PM
          • MicroSMD Lab
            ASUS ROG Zephyrus GPU Mosfet repeat failure
            by MicroSMD Lab
            The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
            01-10-2024, 06:36 AM
