Lg 42 px5d
  • Techstar
    Tv Restoration
    • Dec 2012
    • 122
    • United Kingdom.
    Lg 42 px5d
    Hi could any one with experience of working on this model of tv tell me if there is any difference in the power supply boards between the same model number. In a nut shell - are all the power supply boards exactly the same on these models and interchangable with other models of 42PX 5D.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 42 px5d
    If the connectors are the same and mounts it should work.
    • Techstar
      Tv Restoration
      • Dec 2012
      • 122
      • United Kingdom.
      Re: Lg 42 px5d
      Thanks reece for the help , just one other question does this power supply board have any common failures apart from the 3300 Uf caps on the secondary side (C328, C323 C322 ,C317) . I have 2 psu boards both faulty..
      • Techstar
        Tv Restoration
        • Dec 2012
        • 122
        • United Kingdom.
        Re: Lg 42 px5d
        Well I managed to get the TV "working" it just will not tune in now. I get a message on screen saying no signal input even though there is good signal.
        Non of the other inputs work. When I try to tune the tv the tuning bar on the screen goes as far as 62% then it does not move any more than 62%!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Lg 42 px5d
          If the caps are samwha WB or Wl series then yes they fail commonly and kill the psu logic controller Ic so change them if it uses them. Also the freeview tuner is prolly knackered its common on Lgs.
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
          • shamsudeen
            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
            by shamsudeen
            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
            i know that in linear power supply the noise will be very low comparing to SMPS supply....
            07-19-2025, 07:14 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
